Hole for rod change bracket https://ausmini.com/forums/viewtopic.php?f=2&t=94408 |
Author: | Stev0 [ Wed Dec 14, 2016 7:37 am ] |
Post subject: | Hole for rod change bracket |
Hi, can any of you people who have a rod change gearbox measure the location of the floor hole for the rod change bracket, say with respect to the inner bolt hole for the passenger seat? I am just trying to make sure I've got everything in the right place before it goes off to the panel beaters, especially the tab for the other bolt hole which I have had to fabricate..... I have a photo which is helpful but I am having to guess distances. Thanks! Steve |
Author: | Silobin [ Thu Dec 15, 2016 11:03 am ] |
Post subject: | Re: Hole for rod change bracket |
Hope this helps, A- subframe upper mount hole centreline to left shift Box mount center. 375mm B- subframe upper mount hole centreline to right shift Box mount centre. 378mm C- right inner sill to right shift Box mount. 625mm D- left to right shift Box mount holes. 133mm E- left inner sill to left shift Box mount. 508mm F- front of crossbeam to right shift Box mount. 89mm G- front of crossbeam to left shift Box mount. 92mm Measurements from a 76 Leyland. Best I can manage, Silas |
Author: | Stev0 [ Thu Dec 15, 2016 1:06 pm ] |
Thanks for that Silas.....! ![]() Looks like I was only 10mm out.. Can sleep at night now..... |
