starting a n engine out of the car? https://ausmini.com/forums/viewtopic.php?f=2&t=94387 |
Author: | mooman10_0 [ Sun Dec 11, 2016 11:02 am ] |
Post subject: | starting a n engine out of the car? |
Hi everyone, I have another 1100 motor out the back I am wanting to try and see if it will start. It is sitting in its subframe and everything is on it, all ancillaries. Can I start it up somehow without wiring harness? Thanks, Steve |
Author: | Morbo28 [ Sun Dec 11, 2016 12:23 pm ] |
Post subject: | Re: starting a n engine out of the car? |
Yep you can run a thick gauge cable from the battery positive to the starter motor. Thick Earth cable from battery negative to the engine block. Then a smaller gauge wire from the positive via a momentary switch (from supercheap, repco or Jaycar etc) to the starter solenoid to kick it over. I also run a big battery isolation switch so you can kill the engine when you need to. Voila, good to go. Sent from my Nexus 6P using Tapatalk |
Author: | mooman10_0 [ Sun Dec 11, 2016 1:13 pm ] |
do I need something going to the coil? |
Author: | Phil 850 [ Sun Dec 11, 2016 7:40 pm ] |
mooman10_0 wrote: do I need something going to the coil? Yes. A positive wire. You can pull it off to stop the engine as you will have no ignition key ! |
