It is currently Sat Jul 26, 2025 10:19 am
 Post subject: help my mini wont rev
PostPosted: Wed Nov 09, 2016 8:29 am
Hi I am having some dramas with my 998 van. was diving fine last week went to start it up yesterday and it wont rev at all. It idles fine but when you give it some throttle it dies and coughs. I can rule out the ignition system as it has them same result running on the mega jolt setup and the distributor.
I tried pouring some fuel straight into the carb and it revved up fine (car is running a single 1.5 su) so I figure it is a fuel delivery problem so I put a new fuel filter and pump which did not help. checked the fuel bowl is full and needle and seat work fine. I also blew compressed air through the hose from the bowl to the jet.
what should I be checking next?
thanks
PostPosted: Wed Nov 09, 2016 9:01 am
Not sure if this helps , but Vulcann had fuel issues with his van ,
VulcanBB18
While you have the tank like this, I strongly reccommend shoving some stout wire down the inlet/pickup and make sure it's nice and clear.
My fuel woes came from some concrete like sh!t that was right near the end of the tube, I had to basically chip it off! ...AND there was a similar deposit in the fuel pipe just on the last bend as it comes into the engine bay - took me days and days of runnning out of fuel to find them both!
cheers,
Jacob
PostPosted: Wed Nov 09, 2016 10:34 am
Mechanical fuel pump?
PostPosted: Wed Nov 09, 2016 11:31 am
I put electric facet pump on. will try it out of a jerry can to eliminate the lines and tank this afternoon
PostPosted: Wed Nov 09, 2016 2:02 pm
I was thinking if electric it should be easy enough to check the flow. Is there a fuel filter there somewhere?
PostPosted: Wed Nov 09, 2016 6:08 pm
Fuel flow is good brand new facet pump and new filter. Fuel bowl is always full. Still won't rev past 2000 with the choke on but will be fine if I pump fuel straight into the carby. Took carby off cleaned and used new gaskets to install also put new manifold gasket on not long ago. I am all out of ideas
PostPosted: Wed Nov 09, 2016 6:21 pm
Manifold air leak? Try spraying wd40 around, see if this helps..
PostPosted: Wed Nov 09, 2016 6:54 pm
you can't necessarily rule out an ignition problem just because you've tested it with a distributor and with a megajolt - they may both be timed badly. I'd put the distributor back in and time it to TDC, and use a known good (tested on another engine) coil, leads and plugs
all of the parts of the carby are moving freely? dashpot isn't stuck? has oil in it?
PostPosted: Wed Nov 09, 2016 8:50 pm
thanks
Is the float actually floating and free to move? Rather than jammed or full of fuel :?:
PostPosted: Fri Nov 11, 2016 2:02 am
spark plugs not in need of replacing, i had a similar issue and new plugs & tightening the solid fuel line nut a bit tighter seemed too fix it
PostPosted: Fri Nov 11, 2016 5:40 am
When you try and rev it does it blow a heap of crap out the exhaust ?
1968 Morris Mini Cooper S
PostPosted: Fri Nov 11, 2016 7:00 am
partially blocked main jet
As in a little piece of crap in it
1970 MK2 Cooper S
PostPosted: Fri Nov 11, 2016 7:47 am
Yep, could be...remove the damper piston then stick your finger down the throat of the carby and gently lift the piston and drop it to see if it is moving up and down freely...
PostPosted: Fri Nov 11, 2016 10:17 am
Don't think it's a timing issue as it has run fine before and still revs when fuel is poured in. Fuel float is good and seat seals well. Fuel flow is good so lines are not blocked. Tried 2 sets of plugs and cleaned the carby and hose to fuel bowl out. Going to check for vaccum leaks this avo however all gaskets are new but will give it a go
PostPosted: Fri Nov 11, 2016 11:06 am
If running a brake booster try blocking the brake Vacuum line and see if it make any difference.
"Let us remove your "SHORTS"
