It is currently Sat Jul 26, 2025 11:31 am
PostPosted: Mon Nov 28, 2016 5:44 pm
Well i decided that Mini's are too close to the ground to work on
So i got this to help solve the problem
Gave it a look over and a grease
found a few little things to fix
Will be a great help when i pull the engine out
1970 MK2 Cooper S
PostPosted: Mon Nov 28, 2016 6:23 pm
<snip>
I really don't follow.
PostPosted: Mon Nov 28, 2016 7:25 pm
You won't need to "pull the engine out", unbolt the subframe and up goes the body.
Job done :D
PostPosted: Mon Nov 28, 2016 7:50 pm
No need for that
Just great for unbolting the underneath stuff before lifting the engine
Then if i want i can still move the car around
1970 MK2 Cooper S
PostPosted: Wed Nov 30, 2016 8:08 pm
Awesome. How high is that ceiling may I ask?
Sent from my Nexus 6P using Tapatalk
PostPosted: Wed Nov 30, 2016 9:16 pm
You may wish to install a photoelectric sensor so that you can't lift it up through the roof.
PostPosted: Wed Nov 30, 2016 9:22 pm
Fantastic i was getting one of these
https://www.quickjack.com/car-lift-syst ... -lift.html
but your taking it to another level boom boom
1968 Morris Mini Cooper S
PostPosted: Thu Dec 01, 2016 5:25 am
The Mini fits good as far as the top of the shed goes
Any normal car cant go as high
Plenty of cheap car hoists around for sale
This one needed some repairs to make it safe but its all good now
1970 MK2 Cooper S
PostPosted: Thu Dec 01, 2016 6:13 am
GundyGuy wrote:
No need for that
Yes that would make that easier.
I still much prefer the engine to come out from above, but I have an endless chain that ensures you have millimetre control over the process.
