It is currently Fri Jul 25, 2025 1:50 pm
PostPosted: Mon Nov 28, 2016 5:50 pm
Finally found where the rattle was coming from at the rear end
The lever arm that the hand brake cable attaches too at the backing plate is rather loose and wobbly
Is there a fix for this
1970 MK2 Cooper S
PostPosted: Mon Nov 28, 2016 7:22 pm
There should be a rubber gaiter where the lever comes through the backing plate.
This should dampen out any vibration if it's in good condition.
