https://ausmini.com/forums/
Engine identity
https://ausmini.com/forums/viewtopic.php?f=2&t=94293
Author:  Asiemek [ Sat Nov 26, 2016 4:48 pm ]
Post subject:  Engine identity
Thanks to some fellow forumers i have come into posession of a motor believed to be a 1275. Eng no. N793729P. Any ideas what it is from. Is it a 1275??
Author:  Goldbrocade_62 [ Sat Nov 26, 2016 4:51 pm ]
Post subject:  Re: Engine identity
It is a police number stamped on a mini block more information about the block required
Author:  Matt I [ Sat Nov 26, 2016 4:51 pm ]
That's a NSW police issued number, so it won't tell you what it is. Does the back of the block have cover plates or not?
Author:  gtogreen1969 [ Sat Nov 26, 2016 5:42 pm ]
What is the casting number at the rear of the engine behind No 4 Cylinder
Author:  Asiemek [ Sat Nov 26, 2016 7:25 pm ]
Cheers guys. No cover plates will have a look at the stamping.
Author:  gtogreen1969 [ Sat Nov 26, 2016 7:37 pm ]
Have a look at this thread. It has a bit if info on how to id an engine and gearbox. viewtopic.php?t=92357
Author:  simon k [ Sat Nov 26, 2016 8:16 pm ]
Asiemek wrote:
No cover plates
most likely an ex-1100S type 1275
Author:  gtogreen1969 [ Sat Nov 26, 2016 8:18 pm ]
Probably casting number 12G 1279
Author:  Asiemek [ Sat Nov 26, 2016 9:24 pm ]
simon k wrote:
Asiemek wrote:
No cover plates
So what is an ex-1100s motor. Would it have come out of a morris 1100s or whats the history for these motors. Will take photos tomorrow
Author:  gtogreen1969 [ Sat Nov 26, 2016 9:42 pm ]
Lots of minis that have had a 1275 transplant are using the 1100S engine (12YD engine number).
These have a 12G1279 casing number at the rear. This casing was also used in the UK 1275GT.
You used to be able to pickup an 1100S car for next to nothing.
Author:  Asiemek [ Sun Nov 27, 2016 5:53 am ]
So whhy is it stamped with an N number or did the police use 1100s motors?
Author:  drmini in aust [ Sun Nov 27, 2016 6:09 am ]
Whenever you bought a NEW (non S) block from BMC (I bought 2) they came with NO engine number.
You took it and the receipt to your local fuzz, they allocated a number and directed you to a business of their choosing to get it stamped.
They `may' also have allocated a Police number if the original was machined off and could not be discovered (a maybe).
Code N (for NSW) 79 (year) 3729 (sequential number that year) P (Police).
