https://ausmini.com/forums/
Megajolt wiring diagram for dummies?
https://ausmini.com/forums/viewtopic.php?f=2&t=94215
Author:  mattsmadmini [ Mon Nov 14, 2016 2:09 am ]
Post subject:  Megajolt wiring diagram for dummies?
Anyone have a really easy to read/understand wiring diagram on how to install? I low key am horrible at wiring, something that says, take the green wire from EDIS and add to such and such would be ideal....
Ta :D
Author:  nicholasatkins [ Mon Nov 14, 2016 3:30 pm ]
Post subject:  Re: Megajolt wiring diagram for dummies?
its pretty easy using the installation guide just follow the numbers. had a quick look at mine on the edis plug
no.1 - green/white is the pip signal to mega jolt (shielded cable)
no.2 - red / yellow is the saw signal to mega jolt (shielded cable)
no.5 - green to - on crank sensor (shielded cable)
no.6 - blue to + on crank sensor (shielded cable)
no.7 - cable shields + ground
no.8 - +12v on edis
no.9 - Green/black to ground
no.10 - green/yellow to no.1 brown/geen on coil pack
no.12 - brown/red to no.3 brown/blue on coil pack
no.2 on coil pack purple/black needs a +12v
the mega jolt also needs a +12v and ground
make sure you use shielded cable for the signal wires to the crank sensor and the mega jolt and earth the sheath and all +12v are switched via ignition.
Author:  mattsmadmini [ Mon Nov 14, 2016 11:27 pm ]
thanks amigo
Author:  simon k [ Tue Nov 15, 2016 10:06 am ]
no.8 - +12v on edis
noice... I added this to the how-to
