It is currently Sat Jul 26, 2025 9:47 pm
PostPosted: Sat Nov 12, 2016 5:55 pm
Do i use a copper washer at the slave cylinder end for front drum brakes when connecting the flixi hose, or Is it suppose to seal on a taper without a washer.
PostPosted: Sat Nov 12, 2016 5:58 pm
Cooper washer on hose end. Same on back brakes, and clutch slave cylinder. These threads are 3/8 UNF, so are not tapered.
PostPosted: Sat Nov 12, 2016 7:19 pm
Thanks for that
PostPosted: Mon Nov 14, 2016 5:53 am
Cooper washer...
Muscle memory
