Thermostat https://ausmini.com/forums/viewtopic.php?f=2&t=94202 |
Author: | bluehishouse [ Fri Nov 11, 2016 12:57 pm ] |
Post subject: | Thermostat |
Which order doea the thermostat go in? The book isnt mega helpful. Do i need a gasket between the head and the engine steady? Does the steady go on top of the thermostat cover? Sent from my SM-G900I using Tapatalk |
Author: | whoopspiggy [ Fri Nov 11, 2016 1:29 pm ] |
Post subject: | Re: Thermostat |
Head then gasket, then engine steady then another gasket then thermostat cover Sent from my iPad using Tapatalk |
Author: | Lillee [ Fri Nov 11, 2016 4:10 pm ] |
Head, then thermostat, then gasket, then engine steady, then gasket then thermostat housing. The head should have a groove around it where the thermostat sits into Or to be more precise: Head then thermostat, then gasket sealant, then gasket, then gasket sealant, then engine steady, then gasket sealant, then gasket, then gasket sealant then thermostat housing ![]() |
Author: | awdmoke [ Fri Nov 11, 2016 4:45 pm ] |
Oh, don't forget the sealant on the thermostat stud threads! |
Author: | bluehishouse [ Fri Nov 11, 2016 4:53 pm ] |
Legendary. Cheers guys. Certainly explains the leak =/ Sent from my SM-G900I using Tapatalk |
Author: | Lillee [ Fri Nov 11, 2016 11:12 pm ] |
awdmoke wrote: Oh, don't forget the sealant on the thermostat stud threads! Not necessary if you put enough on the gasket, esp when using Permatex black or grey (silicone based) |
