It is currently Sat Jul 26, 2025 10:24 pm
PostPosted: Fri Nov 11, 2016 11:07 pm
Hi Everyone, this may sound like starnge question, but I am having issues working out the wiring for my tacho. It is a 3 gauge cluster (not sure if its from a clubman or rover) with clubman wiring in a deluxe body.
Hopefully someone here can help fill in a knowledge gap for me. I cannot seem to get my tacho working at all (except the backing light is working).
I'm not sure what year car the tacho or wiring loom is from (ie the tacho does not necessarily match the wiring loom). It seems to have 2 plugs on the back of the tacho (1 bullet connector and 1 spade connector). I was just wondering if anyone knows where these should plug into? I have tried the wiring diagram, but that does not seem to help.
Again, i know that this is very vague, but the cluster is bolted into the car already and is quite difficult to remove again, so I was hoping that someone would be able to explain it for me.
Thanks in advane,
Richard
drugstore-catalog.com
PostPosted: Sat Nov 12, 2016 12:18 am
You have the voltage sensing type usually found on the later cars.
The Male bullet connects to the coil negative terminal
The Male spade connector connects to a 12V Ignition Source
Small screw near male bullet connector is the Earth (usually screwed into PCB)
PostPosted: Sat Nov 12, 2016 12:02 pm
Thanks very much.
I should have just come straight here; would have saved me hours of looking through the different wiring diagrams!
PostPosted: Sat Nov 12, 2016 12:41 pm
Just for reference the other style used on the earlier Leyland Minis is called the current sensing or loop type. It has a male spade and a male and female bullet coming out of the back of the tacho. The bullet connectors are connected in series with the white wire from the ignition switch to the coil positive.
The Male bullet is connected to the 12V Ignition Source
The Female bullet connects to coil positive
The Male spade connector is connected to 12V
Small Screw just below the male spade connector is Earth (usually screwed into PCB)
Users browsing this forum: Bing [Bot] and 108 guests
