Extractors https://ausmini.com/forums/viewtopic.php?f=2&t=94194 |
Author: | GundyGuy [ Thu Nov 10, 2016 11:28 am ] |
Post subject: | Extractors |
Well from what I can see I will have to cut my lcb extractors to get them out before removing the engine So am thinking of a new set that are easier to remove install Any suggestions on brand to get etc Sent from my HTC_PN071 using Tapatalk |
Author: | Scoop [ Thu Nov 10, 2016 1:49 pm ] |
Post subject: | Re: Extractors |
Dont they split apart or have they been welded? |
Author: | GundyGuy [ Thu Nov 10, 2016 1:50 pm ] |
Welded Sent from my HTC_PN071 using Tapatalk |
Author: | simon k [ Thu Nov 10, 2016 1:51 pm ] |
keen to see what people say on this one my current extractors are becoming very 2nd hand and I'm thinking I'll replace them with C-AEG365 Maniflow the joint is back under the floor though which could be a pain My current set have the joint down behind the motor, the Y piece has the bend in it - it makes it easier to get them off because I welded a little piece of rod between the pipes on the Y and I just belt on that with a long bar and it pops off after a few good whacks. Putting them on is the same... |
Author: | simon k [ Thu Nov 10, 2016 2:02 pm ] |
curious about this one - AEG376 has a different size centre branch which seems reasonable |
Author: | drmini in aust [ Thu Nov 10, 2016 2:03 pm ] |
I find the Maniflow LCB comes apart ok IF you use nickel antiseize in the joint. I used kopr-kote before and it set solid with the heat. Needed Mr Anglegrinder's assistance to remove. |
Author: | Lillee [ Thu Nov 10, 2016 3:28 pm ] |
simon k wrote: Yeah this is good enough for most people, unless you are running serious HP with a serious cam and want every last bit out of the engine (sacrificing low end). For that you may want to look at large bore or 3 into 1 |
Author: | jprior2912 [ Thu Nov 10, 2016 5:32 pm ] |
I have these (C-AEG376) http://www.minispares.com/product/Class ... o%20search I really like them, sound nice and maniflow make good stuff. I've taken them apart a few times with no issues. |
Author: | Phil 850 [ Fri Nov 11, 2016 7:24 pm ] |
jprior2912 wrote: I have these (C-AEG376) http://www.minispares.com/product/Class ... o%20search I really like them, sound nice and maniflow make good stuff. I've taken them apart a few times with no issues. I have these too on a stock 1100S but with a RE266SS cam and a 2.95:1 diff. Pulls really strong from down low which is great with the tall diff. Really happy with the combination ![]() |
