It is currently Sat Jul 26, 2025 10:25 pm
 Post subject: 3 syncro Sprite to Mini
PostPosted: Wed Nov 09, 2016 9:07 am
Hi,
Can gears from a Sprite go into a 3syncro Mini gearbox (apart from 1st motion) and vise versa?
Secondly, is it only 1st, reverse and laygear that are different with A and B type gears?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Nov 09, 2016 7:17 pm
If the numbers are the same........ maybe.
PostPosted: Wed Nov 09, 2016 7:25 pm
Mk 1 & Mk 2 smooth-case Sprite gearbox gears definitely won't work in a Mini gearbox. The synchros are a completely different design. Don't know about the MG Midget ribbed-case box.
Curly
PostPosted: Wed Nov 09, 2016 7:34 pm
Smooth case sprite gears use the same old original cone synchro that the Morris 850 had originally. It didn't work properly due to drop gears inertia, so Minis here got baulk ring synchro in 1962/3. As did the sprite with the ribbed case box.
PostPosted: Wed Nov 09, 2016 8:45 pm
the ribbed case box = "egg carton?" or "egg crate?" :D
PostPosted: Wed Nov 09, 2016 9:39 pm
I need to donate a set of gears to a mate. I think its a ribbed case and he has a 1st motion shaft, just nothing else. Does it need a laygear that would have the same teeth count as his 1st motion? (I think the sprite has 19 teeth and the mini has 18)
5/72 Clubman Gt
PostPosted: Thu Nov 10, 2016 1:57 pm
Pretty sure m2a mk3 sprite is same laygear as 998 cooper and 1275 mg is same as mk1 cooper s
PostPosted: Fri Nov 11, 2016 11:41 am
Mk3 spridget laygears are 22G1100s like mk1 S. They just spin the other way.
I'm pretty sure the third and second speed gears are the same too (check against know samples) but the 1st gear Hub and ring are slightly different enough to permit the 2nd speed syncro balls escaping when selecting 1st.
....you just lost him his insurance bonus!
997
PostPosted: Fri Nov 11, 2016 5:07 pm
Thanks for that info. I will have to sit down and figure out what to do. Going to get expensive replacing all the gears (if available that is)!
5/72 Clubman Gt
Users browsing this forum: Bing [Bot] and 102 guests
