https://ausmini.com/forums/
Tacho sitting at 1500 - **FIXED** !!
https://ausmini.com/forums/viewtopic.php?f=2&t=94160
Page 1 of 2
Author:  1275LS [ Sat Nov 05, 2016 4:57 pm ]
Post subject:  Tacho sitting at 1500 - **FIXED** !!
Hi all.
Got in the car today and before i had the key in or started I noticed the tacho sitting on 1500 rpm.
Startup went to 2000.
It is a 1275ls with the standard cluster.
Ideas?
Author:  9YaTaH [ Sun Nov 06, 2016 8:55 am ]
Post subject:  Re: Tacho sitting at 1500
Voltage stabiliser?
Author:  Jonnoh [ Mon Nov 07, 2016 8:43 am ]
I think it's impossible to guess what the problem is.
Author:  Convertible Mini [ Mon Nov 07, 2016 9:25 am ]
10 out of 10 points to Jonnoh .... Tacho works with full 12 volts from Ignition not from stabilizer 10 Volt supply. I wonder why people who are not sure what they are saying still put their Guess in. It confuses those who are trying to fix something themselves and could be potentially damaging. Sorry I had to say it but someone had to. If my comment is not liked please feel free to delete it.
Author:  gtogreen1969 [ Mon Nov 07, 2016 10:26 am ]
I had a a sticking tacho like that but it was only the needle rubbing on the face. Just had to bend it up a bit to clear.
Author:  GundyGuy [ Mon Nov 07, 2016 10:53 am ]
I think it's mechanical
As in the needle isn't returning to zero
Have to read the question properly
Sent from my HTC_PN071 using Tapatalk
Author:  Stev0 [ Mon Nov 07, 2016 11:10 am ]
Yes, possibly the movement itself has had it or it's sticking....pull it apart and have a look. If you rotate it quickly the needle should wobble due to inertia, if it appears stuck it probably is.
Author:  9YaTaH [ Mon Nov 07, 2016 1:09 pm ]
FIIK! :lol:
Author:  Phil 850 [ Mon Nov 07, 2016 7:40 pm ]
When you turned the engine off, did it go back to 1500.
Try tapping the gauge with your finger.
My mechanical temp gauge only cools down to 50C, but a gentle tap and it goes all the way back to the stop.
Author:  peterb [ Mon Nov 07, 2016 7:44 pm ]
Maybe it's the idle screw to tight. :-) :-) :-)
Author:  jubblies [ Mon Nov 07, 2016 9:03 pm ]
+1. That's what mine does and it's the same era (late '78)
It gets stuck at about 500-1000rpm but then is ok when running. Some times it returns to 0.
I just call it an 'undocumented feature'!
Author:  9YaTaH [ Tue Nov 08, 2016 7:06 am ]
I just call it an 'undocumented feature!
Maybe you should carry out an Expanded Gage (*) R&R study on your speedo Jubblies :?:
Further reading here:
http://support.minitab.com/en-us/minita ... r-r-study/
(*) http://www.dictionary.com/browse/gage
Author:  1275LS [ Wed Nov 09, 2016 6:05 am ]
Thanks Tony. No problems from me.
Author:  1275LS [ Sat Nov 12, 2016 10:13 pm ]
Post subject:  Re: Tacho sitting at 1500 - **FIXED** !!
Ok so got in the car tonight and gave the tacho a gentle bump on the side. I could hear a spring or something inside twang or bounce a bit and the needle just drifted its way back to zero.
Started her up and hey presto, idle! revs up and down and the needle follows nicely. I reckon it just got itself out of sorts over a speed bump or something.
Author:  Minicooper4me [ Sun Nov 13, 2016 8:05 am ]
Dare you to tap it again !
