https://ausmini.com/forums/
Valve Guides Whats Best
https://ausmini.com/forums/viewtopic.php?f=2&t=94126
Author:  GundyGuy [ Mon Oct 31, 2016 5:33 pm ]
Post subject:  Valve Guides Whats Best
Whats the best Valve Guide to use
Cast Iron or Bronze
Author:  TheMiniMan [ Mon Oct 31, 2016 5:35 pm ]
Post subject:  Re: Valve Guides Whats Best
cast iron guides for normal valves
bronze guides for stainless valves
"Generally"
Author:  drmini in aust [ Mon Oct 31, 2016 7:02 pm ]
The original cast iron guides but with k-liners fitted. Not cheap, but they give best heat transfer and run minimum clearance.
Work fine with stock valves or SS ones.
[edit]
re bronze guides, I do run a set in my car. These current manganese bronze ones tend to shrink when fitted, definitely need a 9/32" reamer through them after fitting. And one of mine even then tried to grab an exhaust valve when first run, so I had to pull the head and ream them a second time. To be sure, to be sure...
That was 50,000 miles ago (with 1.5:1 forged rockers) and they are still working fine.
