https://ausmini.com/forums/
Can you a MPI head on a non injected 1275 without any proble
https://ausmini.com/forums/viewtopic.php?f=2&t=94081
Author:  whoopspiggy [ Thu Oct 27, 2016 6:12 am ]
Post subject:  Can you a MPI head on a non injected 1275 without any proble
Hello I was wondering if anyone can tell if there is problems with bolting a MPI head onto a series (pre a+) 1275? Thanks Scott
Author:  Harley [ Thu Oct 27, 2016 8:00 am ]
Post subject:  Re: Can you a MPI head on a non injected 1275 without any pr
Shouldnt be any they were the same as everything else.
Its the mpi blocks that are different cause they dont have a distributor.
Author:  whoopspiggy [ Thu Oct 27, 2016 8:10 am ]
. Thanks, the CC is the same size, it all looks straight forward, I am assuming manifolds will bold straight up
Author:  peterb [ Thu Oct 27, 2016 5:54 pm ]
:lol: Crikey, if you put a MPI head on it, you'll have to get it re-engineered as a new car.
Author:  IndigoBlueCooperS [ Thu Oct 27, 2016 6:21 pm ]
I have an MPI head on a 1275. It did not have fittings for the standard temp sender, bypass hose and heater outlet.
It may not be a problem for your application, and some MPI heads may have these fittings.
Author:  whoopspiggy [ Thu Oct 27, 2016 8:59 pm ]
Ta, doesn't sound too scared
Author:  whoopspiggy [ Thu Oct 27, 2016 9:01 pm ]
. I know, it will create expectations of fancy injection stuff
