https://ausmini.com/forums/
Removal of number plate Flap
https://ausmini.com/forums/viewtopic.php?f=2&t=94063
Author:  zulu_warrior1976 [ Mon Oct 24, 2016 12:04 pm ]
Post subject:  Removal of number plate Flap
Hey Y'All,
Am trying to remove the number plate flap so I can get the colour matched.
The screws / bolts look like they can be undone by an allan key but I tried last night and they actuall all seem to be round... not rounded off by poor application of an allan key but actually round!?!
They are a tad rusty and I have put some penetrene on them to remove them but without anything to gain any purchase with a suitable "tool" to remove these strange bolts I am somewhat at a loss.
I can take a photo and post it later tonight as it was too dark last night....
Has anyone experienced this? Know what the bolts are? is there a special tool to remove them?
Zulu
Author:  Goldbrocade_62 [ Mon Oct 24, 2016 12:07 pm ]
Post subject:  Re: Removal of number plate Flap
They are Phillips screws and very easily rounded off
Author:  winabbey [ Mon Oct 24, 2016 12:20 pm ]
I'm having exactly the same problem in removing mine for exactly the same reason - to match the paint colour. I've removed two screws each side with a Phillips head driver bit but the top two require an angled approach and are now rounded due to my persistence with a power driver. I've used lots of WD40 front and back but no cigar so far.
Next option is to get a small dremel cutting bit in there to remanufacture the slots. Other option is one of those manual driver tools, the one with a driver bit that you hit on the end with a hammer to cause a twisting action. I haven't got one so am trying other options before shelling out $30 or so for a tool I may only use once.
Author:  zulu_warrior1976 [ Mon Oct 24, 2016 12:21 pm ]
hmm, they don't appear to be on mine...
I'll need to take a photo and post.
Author:  zulu_warrior1976 [ Mon Oct 24, 2016 12:22 pm ]
Dremmel is a good idea. I'll have to wait for the penetrene to work its magic first.
Author:  winabbey [ Mon Oct 24, 2016 12:34 pm ]
Author:  winabbey [ Mon Oct 24, 2016 1:21 pm ]
Hallelujah !! Just managed to get one of the last screws out using a normal screwdriver. The flap then slides out so no need to get both brackets off, just one side.
Author:  zulu_warrior1976 [ Mon Oct 24, 2016 4:05 pm ]
well done. I'm going to have a crack tonight.
Author:  Bill B [ Mon Oct 24, 2016 5:22 pm ]
For some reason, those little setscrews are hard to remove and it's probably worth using one of those impact drivers that have to be hit "hard" with a hammer. The setscrews are replaceable but they will round over if you are not brutal to start with.
Author:  zulu_warrior1976 [ Mon Oct 24, 2016 8:03 pm ]
The penetrene has done the trick. All out. Yippee!
