It is currently Sat Jul 26, 2025 10:18 pm
PostPosted: Mon Oct 24, 2016 12:04 pm
Hey Y'All,
Am trying to remove the number plate flap so I can get the colour matched.
The screws / bolts look like they can be undone by an allan key but I tried last night and they actuall all seem to be round... not rounded off by poor application of an allan key but actually round!?!
They are a tad rusty and I have put some penetrene on them to remove them but without anything to gain any purchase with a suitable "tool" to remove these strange bolts I am somewhat at a loss.
I can take a photo and post it later tonight as it was too dark last night....
Has anyone experienced this? Know what the bolts are? is there a special tool to remove them?
Zulu
Zulu...
1967 mini Cooper S
PostPosted: Mon Oct 24, 2016 12:07 pm
They are Phillips screws and very easily rounded off
PostPosted: Mon Oct 24, 2016 12:20 pm
I'm having exactly the same problem in removing mine for exactly the same reason - to match the paint colour. I've removed two screws each side with a Phillips head driver bit but the top two require an angled approach and are now rounded due to my persistence with a power driver. I've used lots of WD40 front and back but no cigar so far.
Next option is to get a small dremel cutting bit in there to remanufacture the slots. Other option is one of those manual driver tools, the one with a driver bit that you hit on the end with a hammer to cause a twisting action. I haven't got one so am trying other options before shelling out $30 or so for a tool I may only use once.
PostPosted: Mon Oct 24, 2016 12:21 pm
hmm, they don't appear to be on mine...
I'll need to take a photo and post.
Zulu...
1967 mini Cooper S
PostPosted: Mon Oct 24, 2016 12:22 pm
Dremmel is a good idea. I'll have to wait for the penetrene to work its magic first.
Zulu...
1967 mini Cooper S
PostPosted: Mon Oct 24, 2016 12:34 pm
PostPosted: Mon Oct 24, 2016 1:21 pm
Hallelujah !! Just managed to get one of the last screws out using a normal screwdriver. The flap then slides out so no need to get both brackets off, just one side.
PostPosted: Mon Oct 24, 2016 4:05 pm
well done. I'm going to have a crack tonight.
Zulu...
1967 mini Cooper S
PostPosted: Mon Oct 24, 2016 5:22 pm
For some reason, those little setscrews are hard to remove and it's probably worth using one of those impact drivers that have to be hit "hard" with a hammer. The setscrews are replaceable but they will round over if you are not brutal to start with.
PostPosted: Mon Oct 24, 2016 8:03 pm
The penetrene has done the trick. All out. Yippee!
Zulu...
1967 mini Cooper S
Users browsing this forum: drmini in aust and 91 guests
