It is currently Sun Jul 27, 2025 7:58 am
 Post subject: Clubman Side Mirrors
PostPosted: Wed Jul 03, 2013 10:23 pm
I need one...and nowhere sells them!
Where does one go to purchase such a thing???
I don't want to mess around drilling etc to fit fancy ones, just want to chuck one easily.
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Thu Jul 04, 2013 8:31 am
If you after something like this?
http://www.minispares.com/product/Class ... .aspx|Back to shop
I have a new pair
PostPosted: Thu Jul 04, 2013 8:36 am
Same style but those mounting holes don't line up with mine, I tested a pair off a mate. I know drilling holes isn't hard but it leaves my current holes uncovered and would need filling, painting etc.
Really chasing the standard clubby ones!
Cheers anyway!
1975 Clubman
PostPosted: Thu Jul 04, 2013 8:40 am
I have a new pair
Not sure if these Tex ones are genuine Clubby mirrors from yesteryear (I doubt it)- but Karcraft also sells them, in chrome.
Note the standard base they come with is plastic rubbish, it goes soft in the summer heat then the mirror can fall off like mine did.
If you buy the Tex chromed plinth from Minispares the mount is more robust, and it lifts the mirror up a bit for better visibility.
p/no CZH3521
[edit] Karcraft now stocks this plinth.
http://www.minispares.com/product/Class ... o%20search
Last edited by drmini in aust on Fri Oct 14, 2016 11:00 am, edited 1 time in total.
 Post subject: Re: Clubman Side Mirrors
PostPosted: Thu Jul 04, 2013 9:20 am
The Mini King
The original Clubman Mirror was Made in Australia By a Company called Wibroc,
Another Australian Manufacturer who no longer exists
There is a Guy who attends swap meets who refurbishes these and sells them
I do the same but at present I do not have any to refurbish, Check ebay, sometimes they come up there,
As a matter of interest this mirror was fitted standard to the Mini* P76 *Marina* and Morris1500,and was avail as an accessory for all other makes of cars
PostPosted: Thu Jul 04, 2013 11:14 am
Appreciate the info, ill be on the lookout.
Those Mirrors don't line up with my current ones Kev, otherwise id fit the pair that's sitting in my ute as we speak!
1975 Clubman
PostPosted: Thu Jul 04, 2013 4:06 pm
They don't exist as far as I've found out.
Carbon fibre bike mirrors are pretty cheap though.
PostPosted: Thu Jul 04, 2013 4:26 pm
When I fitted a Tex one to my Mini, there was 1 hole that wasn't covered. It now has a shiny chromed screw in it, doesn't look too bad.
PostPosted: Thu Jul 04, 2013 6:23 pm
As John Smidt has already stated, the mirrors were made by Wibroc for BMC. In fact they were simply one of Wibroc's standard mirror product range. In the brochure below they are the Panorama mirror with Continental head.
They regularly appear on eBay although more often with the rectangular or round head. If you aren't especially after originality of the mirror head but want the correct base you can use one of these.
I purchased the following one with a rectangular head on eBay recently - $8 plus postage. Put Wibroc in your eBay search and you should find one.
http://www.ebay.com.au/itm/151062972140 ... 1439.l2649
PostPosted: Fri Oct 14, 2016 3:28 pm
Hey John,
I have 3 or 4 of them for my GT's but they are a bit tatty. How do you refurbish and how much to do it?
It's mainly the bases.
Rod
PostPosted: Fri Oct 14, 2016 3:36 pm
Rod - this thread is from 3 years ago, just revived by GuamMini for some reason. I'll ask John next time we speak if you wish?
PostPosted: Fri Oct 14, 2016 3:46 pm
Did not notice the dates but would still be interested to know if John can refurbish them.
Rod
PostPosted: Sat Oct 15, 2016 4:02 pm
Rod
As the Splines in the bases get chewed out from turning the mirror to different positions and then they do not stay where they are supposed to and droop all the time and eventually wear a spot in your paint.
I didnt think these were repairable So am interested as well
PostPosted: Sun Oct 30, 2016 11:58 am
Picked up a nos clubman one today for $1 still has the plastic wrap on the stainless back of the mirror the screws that hold the tension and on the arm still look like new
PostPosted: Sun Oct 30, 2016 3:13 pm
Nice find
