It is currently Sat Jul 26, 2025 11:32 am
 Post subject: Valves and Rockers
PostPosted: Sat Oct 15, 2016 11:56 am
Well today was "Fit the new MED 1.5-1 Rockers day"
Well like usual it didn't go to plan
When i went to set the clearances i found 1 inlet valve was a little bit too short above the collet
Result was the new rocker was fouling the spring retainer before it would touch the valve
So when the valve went to open the rocker was pressing on the spring retainer first
So its off with the new and back on with the old till i sort out another head to go on
These sort of things make me want to scream :evil:
1970 MK2 Cooper S
 Post subject: Re: Valves and Rockers
PostPosted: Sat Oct 15, 2016 12:29 pm
I put a set on a mk1 S head and had to pack them up 2mm to get adjustment
PostPosted: Sat Oct 15, 2016 1:36 pm
I think two sets of the 1.3 mm shims from minispares etc) did the trick for me in getting geometry better if you are looking for a bought solution ... but i had to grind the angles a little further back into the shim for better all round clearance ..
PostPosted: Sat Oct 15, 2016 2:43 pm
Both GR and Minis Plus have shims in 1.0 and 2.0mm.
PostPosted: Sat Oct 15, 2016 3:41 pm
Everything else was fine
just that 1 inlet valve
i measured it and it was 0.030" shorter than the other 3
Was thinking of a stem cap to bring up the height
Dont want to shim up the pedestals as the rockers were near horizontal
But now i will leave it until i get another head ready and make sure the stem heights are correct
1970 MK2 Cooper S
PostPosted: Sat Oct 15, 2016 8:11 pm
So don't you just need one new inlet valve ?
PostPosted: Sat Oct 15, 2016 8:49 pm
Or 7 shorter valves.
PostPosted: Sun Oct 16, 2016 4:21 am
You Can try using Datsun lash Caps on top of the Valve stem to give you more Valve length perhaps.
"Let us remove your "SHORTS"
PostPosted: Sun Oct 16, 2016 6:22 am
What model Datsun
1970 MK2 Cooper S
PostPosted: Sun Oct 16, 2016 7:09 am
Darsun 1200 I think, they have 7mm valve stems.
