https://ausmini.com/forums/
Fuse ratings
https://ausmini.com/forums/viewtopic.php?f=2&t=93995
Author:  glenndunn [ Sun Oct 16, 2016 6:47 am ]
Post subject:  Fuse ratings
While I was wiring up my black box to the fuse box recently I noticed my two fuses were only 20 amps and when I looked the Electrical section of the workshop manual it stated 35 amps, is this correct ?
Author:  drmini in aust [ Sun Oct 16, 2016 7:09 am ]
Post subject:  Re: Fuse ratings
Yes, 35 is correct. 20 are too small.
Author:  glenndunn [ Sun Oct 16, 2016 8:36 am ]
Thanks again Dr
Author:  Convertible Mini [ Sun Oct 16, 2016 7:42 pm ]
What is there in a standard mini that requires 35 Amp to run? 35 amps it too high and unsafe even though it was the manufacturer's idea. 20 amps is ample and safer.
Author:  gtogreen1969 [ Sun Oct 16, 2016 8:23 pm ]
The original fuses were Lucas 17/35, designed to run at 17 amps continuous and will go up to 35 amps before blowing in 1 second. The 20 amp AGC will run at 20 amps and blow at 40 amps in 1 second. Either one will be fine.
Author:  glenndunn [ Mon Oct 17, 2016 6:54 am ]
Seems to be a couple of different thoughts here, should I change them to 35 amps or leave them as is
Author:  Hobson [ Mon Oct 17, 2016 9:00 am ]
The way I see it, what do you want to go first the fuse or component. If 20 is working then use 20, if they are blowing you can try a 35, or something is wrong.
Author:  deluxe67 [ Mon Oct 17, 2016 9:03 am ]
Got 20's in mine, no problems so far (3 years?)
Author:  drmini in aust [ Mon Oct 17, 2016 9:03 am ]
At least if you blow a fuse, the headlights still work. :) They are unfused originally.
Author:  Mick [ Mon Oct 17, 2016 9:09 am ]
So was the ignition!
I suppose the thinking was if it couldn't drive home, then let it burn :lol:
Author:  glenndunn [ Tue Oct 18, 2016 6:54 am ]
Thanks all
I think I will leave the 20 amp fuses in and see what happens
Author:  9YaTaH [ Tue Oct 18, 2016 7:01 am ]
glenndunn wrote:
Thanks all
but keep some spare "factory recommended" fuses in the car :idea:
