https://ausmini.com/forums/
Rear toe-in measurement point?
https://ausmini.com/forums/viewtopic.php?f=2&t=93992
Author:  Morbo28 [ Sat Oct 15, 2016 12:30 pm ]
Post subject:  Rear toe-in measurement point?
Hi there, I need to set the tracking on the rear wheels. One source says
As a starting point, set them at 1/16” toe-in.
I'm just checking I'm using the right measurement points...I would assume I measure the overall width from one tyre to the other. The width of the outer edge of the front-most part of the tyres and compare to the overall width of the outer edge of the rear-most part of the tyres. And make sure the front overall width is 1/16" narrower than the rear measurement.
Is that right?
Author:  phillb [ Sat Oct 15, 2016 12:52 pm ]
Post subject:  Re: Rear toe-in measurement point?
Is that right?
not sure about the details but make sure you measure from the same point on the tyre i.e. you need to turn both wheels half a turn in case wheels or tyres are not perfect.
Author:  gtogreen1969 [ Sat Oct 15, 2016 1:09 pm ]
I setup a string line box around the car to measure the rear toe in.
Author:  Morbo28 [ Sat Oct 15, 2016 3:03 pm ]
Thanks guys. Whether I use a string line or just measure it, is the theory right that I posted?
Is the measurement for example 1/16" narrower over all or say 1/16" in from the string line? There's a few ways that measurement could be applied.
Author:  gtogreen1969 [ Sat Oct 15, 2016 4:48 pm ]
You need to get the toe in as close to 1/32” (0.8mm) each rear wheel.
I also tried the rear wheels straight and found it ok but I went to toe out it felt very skittish.
I take the measurements against the sidewall at the same height as the manual says to do the front wheels but on the outside.
http://www.ausmini.com/manuals/Mini%20W ... eering.pdf
"Measurements must be made on a 14.5" diameter (368.3mm) on the sidewall of the tyre at a distance of 9.4" (239mm) above the ground."
Here is a photo showing my very technical setup. I use a brick at each corner and 2 pipes that I roll up to put tension on the string. If you zoom in you will see 2 chalk marks on the sidewall. They are 9.4" off the ground and 14.5" diameter. All you need now is a ruler or a vernier calliper depth gauge to measure the distance from the string to the sidewall.
Author:  Morbo28 [ Sat Oct 15, 2016 5:19 pm ]
Perfect, I'll do it just like you did, thanks! :)
