Mini air con https://ausmini.com/forums/viewtopic.php?f=2&t=93956 |
Page 1 of 4 |
Author: | decsmith [ Sun Oct 09, 2016 7:11 pm ] |
Post subject: | Mini air con |
Hey, I'm trying to trace back why the mini doesn't have any 12v power hitting the compressor. I've traced it from the compressor back to a harness plug on the passenger side bulk head, now I have the dash apart. Any suggestions on why she's not getting power? The switches on the dash work perfectly |
Author: | gtogreen1969 [ Sun Oct 09, 2016 7:16 pm ] |
Post subject: | Re: Mini air con |
There is a low pressure switch that will prevent the clutch engaging if low or no gas. |
Author: | decsmith [ Sun Oct 09, 2016 7:32 pm ] |
Had it regassed this morning. Turns out my A6 aircon fuse in the cabin keeps blowing 10amp. I chucked a 30amp in there to test and it blew immediately too.. Looks like a short circuit...where the heck is that going to be? |
Author: | gtogreen1969 [ Sun Oct 09, 2016 7:37 pm ] |
Remove all plugs from the aircon components and start reconnecting one at a time. |
Author: | gtogreen1969 [ Sun Oct 09, 2016 7:39 pm ] |
Compressor clutches and condensor fans short out often. |
Author: | decsmith [ Sun Oct 09, 2016 7:47 pm ] |
Should I start at the dash and work through the plugs to the compressor? |
Author: | gtogreen1969 [ Sun Oct 09, 2016 8:02 pm ] |
The bulkhead plug will tell you if it is inside the cab or under the bonnet. If under the bonnet then i would pull the compressor clutch and consensor fan and then see if it blows. |
Author: | decsmith [ Sun Oct 09, 2016 8:25 pm ] |
Thanks gtogreen I've unplugged the bulkhead harness plug and it's still blowing. I've unplugged the switch panel plug to the temp/blower and it blows...arghhhhhh! Could it be a dodgy relay? |
Author: | gtogreen1969 [ Sun Oct 09, 2016 8:44 pm ] |
If there is a similar relay then swap it over to test it Keep plugging away at it ( or in your case - unplugging away) |
Author: | Harley [ Sun Oct 09, 2016 9:17 pm ] |
The AC relay unit looks like the ECU relay unit, however it's not the same despite its looks. Swapping it with the ECU one may risk damage to lots of things if it is indeed the problem. |
Author: | decsmith [ Sun Oct 09, 2016 9:40 pm ] |
Yea, I did see it under the dash and the one on the engine..I won't be swapping those over! Thanks for the heads up. I've managed to find a wiring diagram for the ac. I've pulled every plug in relation to the fuse box, I'm now going to try and rewire the ignition side to the fuse box....what a night this has turned into! |
Author: | decsmith [ Sun Oct 09, 2016 9:41 pm ] |
Here's the diagram |
Author: | decsmith [ Sun Oct 09, 2016 9:42 pm ] |
I've pulled the plugs to the thermostat, relay module and switch pack and it still blows |
Author: | decsmith [ Sun Oct 09, 2016 9:54 pm ] |
Okay, all 3 are unplugged 100%. I have wired directly from ignition terminal (white) to fuse box white and pop goes the fuse. I am completely out of ideas now |
Author: | Harley [ Sun Oct 09, 2016 10:07 pm ] |
Ckeck if one side of the fuse is earthed? |
Page 1 of 4 | All times are UTC + 10 hours |
