It is currently Sun Jul 27, 2025 7:41 am
 Post subject: Nyloc knut in gearbox?
PostPosted: Thu Oct 27, 2016 6:02 pm
Hi Guys
Just about to bolt up my gearbox to the block and wanted to check if it's okay to use a Nylock nut in the gearbox or if the nylon will deteriorate over time.
Welcome any advice before I put it all together!
PostPosted: Thu Oct 27, 2016 6:30 pm
Nyloc nuts are used on driveshaft yokes where they can cop lots of oil and I think the speedo drive gears in the box are in nylon too.
PostPosted: Thu Oct 27, 2016 6:46 pm
it's fine, I've had one holding my central oil pickup for many years
PostPosted: Thu Oct 27, 2016 6:57 pm
Great news thanks fellas
PostPosted: Thu Oct 27, 2016 7:05 pm
there's also the question of why you actually want to put a fictitious wizard's coin in your gearbox.... http://harrypotter.wikia.com/wiki/Knut
PostPosted: Fri Oct 28, 2016 2:27 pm
Are you bored Simon? Anyhow you got me to look at the link :D
PostPosted: Fri Oct 28, 2016 3:37 pm
Or a polar bear - https://en.wikipedia.org/wiki/Knut_(polar_bear)
Nick
