It is currently Sun Jul 27, 2025 4:26 pm
 Post subject: Lucas horn not working.
PostPosted: Mon Oct 03, 2016 12:57 pm
Polished up my Lucas horn from black to a nice and shinney finish now it doesn't work.
When I first mounted back on the car it worked but only just, very faint and sounded as if it was under water.
So I played with the flat screw on the back hoping to adjust or something and now its shorting somewhere because as soon as I plug it in I blow the fuse. Looks great though haha.
Anyone help me? Can you still get them, or can mine be fixed? Or does someone have one for sale?
My car is a 1970 mk2 cooper s.
PostPosted: Mon Oct 03, 2016 2:42 pm
What process did you use to make it bright and shiny?
PostPosted: Mon Oct 03, 2016 5:40 pm
Paint stripper,polishing mop on my bench grinder and elbow grease.
I goggled Lucas horn repair and learnt a little about them. So I opened mine up and the flat screw on the back that I adjusted was adjusting the contacts. So by screwing all the way in I think i've created the short. Nothing seems fused at all but I don't know where this screw should be adjusted to. It still doesn't work.
