It is currently Sun Jul 27, 2025 8:36 pm
PostPosted: Mon Oct 03, 2016 8:18 pm
I know its a long shot but does anyone have a picture of a simplex timimg chain both sides.
I only seem to have duplex ones.
the reason is in the link below
viewtopic.php?f=2&t=93902
Thanks
Bernard
PostPosted: Mon Oct 03, 2016 9:10 pm
Yes, I have just replaced mine. Will send you a photo tomorrow.
Is the bit you found on your sump hollow? I just measured a link in the chain I have and it was 6.25 mm diameter - what is the diameter of your bit?
PostPosted: Mon Oct 03, 2016 9:22 pm
hi
yes it may have been hollow
my part measures 3.25mm
the ones on my duplex chain measure 3.55mm
thanks
Bernard
PostPosted: Tue Oct 04, 2016 10:34 am
Image of timing chain link as requested - the pin that does through the roller is about 3.2 mm diameter and is dimpled on each end
- might be the bit you found. The roller is larger (6.4 mm roughly)
The pin is not stepped on the end - after installing in the link, it looks like it has been punched in the centre to flare it out slightly yo hold it in place
I can send you my old chain if you want otherwise it's going in the bin - my new chain cost me just $10 so it may be just as cheap to buy a new one to compare.
Can send other pics if you need them
Neil
PostPosted: Tue Oct 04, 2016 5:38 pm
Thanks Neil
very helpfull
i recons its also a link pin
PostPosted: Wed Oct 05, 2016 3:30 pm
If you think it's a timing chain pin, don't run your engine because the timing chain could break and that would be a disaster.
This is what happened to am MGF which broke its timing belt - yes, that's a valve embedded in the top of the piston
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62 and 95 guests
