https://ausmini.com/forums/
Brake Cylinders from Mini Spares - anyone else had issues??
https://ausmini.com/forums/viewtopic.php?f=2&t=93901
Author:  Asiemek [ Sun Oct 02, 2016 12:57 pm ]
Post subject:  Brake Cylinders from Mini Spares - anyone else had issues??
bought a set of front brake cylinders from mini spares uk but found the securing bolt holes don't match my backing plates. Did I get the wrong ones?
part numbers are
GWC126MS
GWC127MS
fitting to a 65 deluxe
Author:  drmini in aust [ Sun Oct 02, 2016 2:45 pm ]
Post subject:  Re: Brake Cylinders from Mini Spares - anyone else had issue
Check the cylinder bores. 15/16" ones are slightly different hole centres to the 1" ones
So they don't get mixed.
File the backplate holes, or swap cylinders.
Author:  Asiemek [ Sun Oct 02, 2016 6:12 pm ]
Mmmmmm thanks for the reply will have a look further into this. Does it matter which one i install?
Author:  Scoop [ Sun Oct 02, 2016 6:30 pm ]
At least make sure they are all the same!
