It is currently Sun Jul 27, 2025 9:16 pm
 Post subject: Electrical help
PostPosted: Mon Sep 26, 2016 7:12 pm
Need help please. I've got an electronic Aldon y distributor and it keeps blowing the module in it. Any able to help me with the problem? The first one lasted one start, the second lasted about 6 starts. The only wiring damage I can see is on the number 3 peg on the back of the ignition where the brown and blue wire goes is brown at the base.
 Post subject: Re: Electrical help
PostPosted: Mon Sep 26, 2016 8:42 pm
How do you know the module is blown ?
Sorry i don't have the Aldon but i did install my accuspark with blackbox and got it going first go
1968 Morris Mini Cooper S
PostPosted: Mon Sep 26, 2016 8:47 pm
99% of times Module blows because the Coil is drawing too much Current. Meaning it is too low a resistance or is intermittently shorting. Try a Known new Coil with primary resistance above 1.5 Ohms. Like a Bosch GT40.
"Let us remove your "SHORTS"
Users browsing this forum: fuzzy-hair-man and 91 guests
