It is currently Sun Jul 27, 2025 8:38 pm
PostPosted: Tue Sep 20, 2016 7:16 pm
Hi all,
Anyone had experience with which rocker covers fit over roller rockers? Standard one I have looks like it will hit both exhaust rockers on 1 and 4 and not entirely confident on the rest.
Mini's I grew up with
Slot car couch
PostPosted: Tue Sep 20, 2016 7:58 pm
I have been using TITAN 1.5 :1 roller rockers for 25 years and have never had such problem.
"Let us remove your "SHORTS"
PostPosted: Tue Sep 20, 2016 8:09 pm
I have 1.5s and use a standard cover,
PostPosted: Tue Sep 20, 2016 8:35 pm
What rockers are you using? I've built 2 engines with Yella Terra 1.5 roller rockers and standard rocker covers with no issues.
1970 MK II Cooper 'S' Supercharged 1310 with Megajolt.
1970 MK II Cooper 'S' Original resto project (SOLD)
1962 850 Original. (Under restoration)
1973 Leyland S (My first car. Now rebuilt, so my kids can learn how to drive a real car).
VMCI # 215.
PostPosted: Tue Sep 20, 2016 8:41 pm
Mini sport UK 1.3 for small bore rockers. I might need to set up better in case I am mistaken or contact mini sport and see what they say?
Slot car couch
PostPosted: Tue Sep 20, 2016 8:56 pm
Sometimes with alloy covers and roller (and Corolla) rockers you need to push the cover back slightly. Cut the inside bit off the rubber grommets.
But the stock tin cover should clear 1.3 rollers.
PostPosted: Tue Sep 20, 2016 9:38 pm
Yep same rockers here and the popular alloy cover fits no problems (as did the stock cover).
Sent from my Nexus 6P using Tapatalk
PostPosted: Tue Sep 20, 2016 10:18 pm
The standard cover is the only cover I've found that doesn't foul 1.5 rockers without any modifications. You can buy a new cover without breathers from Minispares and that's what I have
PostPosted: Wed Sep 21, 2016 8:59 am
Have had same problem with alloy rocker covers, Had to get inside with a burr to relieve back of R/C, Place R/C on just nipped down and start engine, Tap it back & forth it will almost disappear ,Look inside you,ll see marks where contact has been made, Grind it back gently, rocker either end is first to touch, Tapping the R/C back once it,s at correct tension will help, I,m using MED rockers and the cast covers from minispares or others.
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
PostPosted: Wed Sep 21, 2016 9:44 pm
Thanks for the feedback all, I'll have a better look on the weekend. I will definitely need to modify the baffle in front of breather pipe but by the sounds of it pressed steel cover should be ok.
I will keep you posted
Slot car couch
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62 and 83 guests
