https://ausmini.com/forums/
Rocker assemblies
https://ausmini.com/forums/viewtopic.php?f=2&t=93749
Author:  GundyGuy [ Tue Sep 13, 2016 6:09 am ]
Post subject:  Rocker assemblies
Has anyone used these products before and if so how did you like them etc
This one
https://www.minisport.com/1-5-1-mini-ro ... escription
And this one
http://www.minispares.com/product/Class ... 0to%20shop
Thinking us fitting 1.5-1 ratio rockers
The other option is to offset bush the std cooper s rockers
All opinions appreciated
Author:  drmini in aust [ Tue Sep 13, 2016 7:33 am ]
Post subject:  Re: Rocker assemblies
These days I prefer the MED ones.
The last 2 sets of Minispares 1.5s I've seen had bent and loose thread adjustment screws from poor manufacturing. Had to swap them with stock Mini screws. I suspect the MSC rockers are now not made in the UK or EU.
http://www.med-engineering.co.uk/produc ... rocker-set
Author:  GundyGuy [ Tue Sep 13, 2016 7:44 am ]
Which MED one do you use
Author:  Morbo28 [ Tue Sep 13, 2016 7:58 am ]
I used Yella Terra in my build and they look to be exceptional build quality. They were highly recommended by the engine builder etc
http://store.yellaterra.com.au/bmc-morr ... -5-yt6302/
Edit - linked to the wrong product. Here's the proper link
http://store.yellaterra.com.au/bmc-leyl ... dj-yt6347/
Author:  drmini in aust [ Tue Sep 13, 2016 8:07 am ]
Mickmini runs the expensive MED ones, I put a set of the cheaper ones I linked onto a 1330 Cooper S recently. They are well made.
A little heavier than some others, but on a road car peaking at 7500 or so they are fine.
The MED rocker shaft is thicker too, 17mm vs 14.3mm. Makes the assembly more rigid.
Author:  FNQ [ Tue Sep 13, 2016 8:36 am ]
The Med LDX have the W shaped rocker posts,... which are super solid but only in 1.5 for racing , both Med kits are well made, .
I have not seen them but the Calver 1.4 ratio, with KC special harder/better adjuster screws ( he got sick of the cheap cheese metal adjusters being too short.) could be a good road car option.
( google calver ST to see)
Also be prepared to buy some shims to correct/optimise geometry if going taller than 1.3.....
On fitting 1.5 to a road car, not normally advised, as in most cases the benefit is felt high up in the rev range but the low to mid ranges can actually suffer depending on cam. but it depends on the whole package, cam/ head, valve size. flow, rockers..... i would also take a punt at saying if you were going to stick to twin 1.5 carbies, you should stick at 1.3ish Rocker ratio,.. IMO a HS6 or HIF44 or weber or dellorto (45) would be almost mandatory to get the most from 1.5 ratio..... ( unless you have the English highly modified twin SU Racing carbs)
Author:  GundyGuy [ Wed Sep 14, 2016 5:25 am ]
Thanks for all the replies
Will look at them all and decide
