It is currently Sun Jul 27, 2025 9:54 pm
 Post subject: measurement qu's
PostPosted: Mon Sep 12, 2016 1:26 pm
Hi everyone,
A couple of quick questions:
What should the diameter be of a standard 1098 piston be?
Also What is the length of a steering rack? (checking to see if postable)
Thankyou,
Steve
 Post subject: Re: measurement qu's
PostPosted: Mon Sep 12, 2016 2:03 pm
a smidgen less than the bore
PostPosted: Mon Sep 12, 2016 2:18 pm
Should be 64.588mm for std bore. Then up by approx 0.5mm for each 20 thou overbore (so +020 is 65.088mm). The pistons normally have something stamped on them if they are larger than stock - eg 020
PostPosted: Mon Sep 12, 2016 2:27 pm
thanks for that, just what I needed :-)
PostPosted: Mon Sep 12, 2016 2:38 pm
mooman10_0 wrote:
Also What is the length of a steering rack? (checking to see if postable).
96 cm
They are often shipped in a piece of plastic plumbing pipe.
PostPosted: Mon Sep 12, 2016 2:57 pm
PostPosted: Mon Sep 12, 2016 2:59 pm
Top of a piston is way less diameter than the bore, to allow for thermal expansion.
The bore clearance at the piston skirt is only around .05mm or less, except for race motors running forged pistons, which need more.
PostPosted: Mon Sep 12, 2016 9:44 pm
Simon K,
Anda nakal!
Indonesian for "naughty person"
Haha....!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Sep 12, 2016 10:14 pm
Old mate should buy some measuring gear!
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Tue Sep 13, 2016 8:06 am
Wish we had a like button. Like
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Tue Sep 13, 2016 5:48 pm
std 998cc & 1098cc bores are 2.542"
PostPosted: Tue Sep 13, 2016 6:42 pm
it's nice to be appreciated... my kids like my jokes too
