Door hinge gaskets https://ausmini.com/forums/viewtopic.php?f=2&t=93715 |
Author: | Boostedmini [ Fri Sep 09, 2016 9:28 am ] |
Post subject: | Door hinge gaskets |
Hi all, Around 12 months ago i had to replace the door hinges as they were flogged out again after the rebuild they got about 10 years ago. my issue is the gaskets i got seem to be a little skinnier or just as wide as the hinge area and the gasket is flat with no lip like the ones i had previously, now my doors have moved slightly the gasket has move a little exposing the back of the hinge. so my question is, does anyone know if these lipped style gaskets are still available? I have checked all the normal sites here and UK and they all seem to be this style without a lip. anyone seen these of late? thanks Grant |
Author: | Lillee [ Fri Sep 09, 2016 3:58 pm ] |
Post subject: | Re: Door hinge gaskets |
Hah! I just did this exact same search Grant and came up with nothing! I ended up buying the regular type from minispares (which actually is made of very thick sturdy gasket material which I am happy about). Not sure about fitment though as I just received them today. |
Author: | drmini in aust [ Fri Sep 09, 2016 4:48 pm ] |
Rubber ones sold now shrink. Cut up an icecream tub. |
Author: | gtogreen1969 [ Fri Sep 09, 2016 4:58 pm ] |
I tried the icecream plastic gaskets the last time i did some hinges. It worked ok. |
Author: | winabbey [ Fri Sep 09, 2016 5:05 pm ] |
gtogreen1969 wrote: I tried the icecream plastic gaskets the last time i did some hinges. It worked ok. Which flavour of ice-cream did you find works best? ![]() |
Author: | gtogreen1969 [ Fri Sep 09, 2016 5:08 pm ] |
Well to tell the truth i used an old 5 litre bottle of oil. I wanted black plastic but couldn't get a black icecream container. |
Author: | 78Clubbie [ Fri Sep 09, 2016 6:15 pm ] |
gtogreen1969 wrote: Well to tell the truth i used an old 5 litre bottle of oil. I wanted black plastic but couldn't get a black icecream container. What flavour of oil ? ![]() |
Author: | Scoop [ Fri Sep 09, 2016 6:39 pm ] |
78Clubbie wrote: gtogreen1969 wrote: Well to tell the truth i used an old 5 litre bottle of oil. I wanted black plastic but couldn't get a black icecream container. What flavour of oil ? ![]() Depends how thick you want the gasket, 0W-20 or 40W-70 ![]() |
Author: | 78Clubbie [ Fri Sep 09, 2016 6:44 pm ] |
Scoop wrote: 78Clubbie wrote: gtogreen1969 wrote: Well to tell the truth i used an old 5 litre bottle of oil. I wanted black plastic but couldn't get a black icecream container. What flavour of oil ? ![]() Depends how thick you want the gasket, 0W-20 or 40W-70 ![]() ![]() ![]() |
Author: | Minicooper4me [ Fri Sep 09, 2016 8:04 pm ] |
Funny Fridays, must be all that rain today. |
Author: | Jenk [ Fri Sep 09, 2016 10:22 pm ] |
The hinge gaskets I got in my full rubber kit from karcraft are the lipped type. |
Author: | deluxe67 [ Sat Sep 10, 2016 2:18 am ] |
Mate, for the life of me I don't understand why your door hinges are shagged after 10 years? Mine are 49 years old and are as they were when new (replaced the pins naturally). But how do the hinges themselves wear out in 10 years or am I missing something?.... |
