It is currently Mon Jul 28, 2025 12:49 am
PostPosted: Sun Sep 04, 2016 7:14 pm
Hey guys,
I have a early (63-64) Morris 850, Im in the process of restoring the car and Im rebuilding the radius arms. I have the radius arm rebuild kit (bearing, brass bush, plastic sleeve) and I've removed the bearing and bush, BUT there is no plastic sleeve, I've tried to use a flat head screw driver on the edges and its not breaking/cracking like plastic should, its metal!..... any ideas? thanks in advance.
PostPosted: Sun Sep 04, 2016 7:29 pm
The original ones where metal
Soak it in some CRC or penetrating oil for a bit
