Early mini 850 Radius Arm rebuild HELP! https://ausmini.com/forums/viewtopic.php?f=2&t=93681 |
Author: | memokab93 [ Sun Sep 04, 2016 7:14 pm ] |
Post subject: | Early mini 850 Radius Arm rebuild HELP! |
Hey guys, I have a early (63-64) Morris 850, Im in the process of restoring the car and Im rebuilding the radius arms. I have the radius arm rebuild kit (bearing, brass bush, plastic sleeve) and I've removed the bearing and bush, BUT there is no plastic sleeve, I've tried to use a flat head screw driver on the edges and its not breaking/cracking like plastic should, its metal!..... any ideas? thanks in advance. |
Author: | kiwiinwgtn [ Sun Sep 04, 2016 7:29 pm ] |
Post subject: | Re: Early mini 850 Radius Arm rebuild HELP! |
The original ones where metal Soak it in some CRC or penetrating oil for a bit |
