Camshaft nut tension https://ausmini.com/forums/viewtopic.php?f=2&t=93672 |
Author: | IndigoBlueCooperS [ Sat Sep 03, 2016 7:10 pm ] |
Post subject: | Camshaft nut tension |
Do we have a list of bolt tensions somewhere? What is the tension for the nut that holds the sprocket onto the camshaft? |
Author: | justfanginaround [ Sat Sep 03, 2016 8:33 pm ] |
Post subject: | Re: Camshaft nut tension |
http://www.minimania.com/Mini_Torque_Wr ... ttings_597 |
Author: | winabbey [ Sat Sep 03, 2016 8:49 pm ] |
IndigoBlueCooperS wrote: Do we have a list of bolt tensions somewhere? What is the tension for the nut that holds the sprocket onto the camshaft? The specifications section of the workshop manual with torque settings is here - http://www.ausmini.com/manuals/Mini%20W ... 20Data.pdf The full manual is here - viewtopic.php?f=25&t=84427 |
Author: | IndigoBlueCooperS [ Sat Sep 03, 2016 10:12 pm ] |
Guys, Thanks for the info. The manual in the link appears to be similar to the ones I have in that it does not have the tension for the camshaft nut. |
Author: | mini0998 [ Sun Sep 04, 2016 7:25 am ] |
http://www.minimania.com/Mini_Torque_Wr ... ttings_597 As posted above. First spec in engine list. |
Author: | drmini in aust [ Sun Sep 04, 2016 7:41 am ] |
I do them to 70 ft/lb with Loctite 262 and no locktab. Never had one come loose. |
Author: | MiniBrad [ Sun Sep 04, 2016 9:57 am ] |
winabbey wrote: IndigoBlueCooperS wrote: Do we have a list of bolt tensions somewhere? What is the tension for the nut that holds the sprocket onto the camshaft? The specifications section of the workshop manual with torque settings is here - http://www.ausmini.com/manuals/Mini%20W ... 20Data.pdf The full manual is here - viewtopic.php?f=25&t=84427 I might of overlooked it, but is there a Clubman workshop manual here winabbey? Brad |
