It is currently Mon Jul 28, 2025 1:58 am
 Post subject: Windscreen Wipers Help
PostPosted: Sun Sep 20, 2015 2:15 pm
Hi,
The wiper on the passenger side needs to come off and rotated a few splines clockwise, as it comes off the windscreen on the down stroke but I cant work out how to remove the retainer??
Also the same wiper is longer in length and as a result hits on the windscreen rubber at top
Is the longer arm simply the wrong item for the car or can it be adjusted... I couldn't find any kind of adjustment?
cheers.
Jenk.
PostPosted: Sun Sep 20, 2015 3:31 pm
The wiper arm should just pull up and off the splined drive. Look closely underneath and it should be clear how to do it.
Either the arm or the blade is too long. Measure both against the other wiper assembly. Replacements of both are readily available.
PostPosted: Sun Sep 20, 2015 5:35 pm
You might need to lever away the tang that holds the arm onto the splines.
PostPosted: Sun Sep 20, 2015 6:54 pm
If you put pressure upwards on the opposite side of the tang, to counteract the arm's spring pressure, it will slide off easy.
PostPosted: Sun Sep 20, 2015 7:21 pm
I do see the front seats and back seats are different
PostPosted: Sun Sep 20, 2015 8:15 pm
A friends 67 Mk1 wipers are much the same, not the being too long issue, but in as much that they override the edge of the screen when wiping or parked. we've tried repositioning the arms but it doesn't make any difference??
johnl
PostPosted: Sun Sep 20, 2015 8:39 pm
[quote="gtogreen1969"]You might need to lever away the tang that holds the arm onto the splines.
Image[/quo
what like get a screwdriver under that lip and prise it upwards, should the tang then just pop out?
Jenk.
PostPosted: Sun Sep 20, 2015 8:41 pm
that make sense Ill give that a crack... thanks Dr.
Jenk.
PostPosted: Sun Sep 20, 2015 8:43 pm
no unfortunately they dont just pull up and off... kinda tried that.
Jenk.
Use fingers, no tools needed.
PostPosted: Sun Sep 20, 2015 8:44 pm
yes all 3 seats are different unfortunately, do you have some matching ones youd like to offload?
Jenk.
PostPosted: Sun Sep 20, 2015 8:47 pm
really! that doesnt make sense the splined shaft will always only rotate to its extremities but if the arm is removed and rotated clockwise a few splines it would have to fall short of it original position wouldnt it??
Jenk.
PostPosted: Sun Sep 20, 2015 9:20 pm
Unfortunately no
PostPosted: Mon Sep 21, 2015 9:19 am
:wink:
Minis have 2 different length wiper blades.
Early ones with original UK type Lucas motors and wiper panel have 10" blades.
Later ones with the OZ type round 12AUW Lucas wiper motor and OZ wiper panel have 11" blades.
The single speed OZ Lucas wiper motors originally had a 110 Deg wiping angle. This caused the RH wiper arm to hit the RHS windscreen rubber.
Later 2 speed OZ Lucas wiper motors had the wipe angle reduced to 105 Deg.
Don't know if single speed motors had the wipe angle reduced when the problem of hitting the rubber became apparent.
Your car has the early type wipers.
Seems like you have the wrong blades or arms or both.
Hope this helps
RonR
68 build Mk1 Cooper S
PostPosted: Mon Sep 21, 2015 10:41 am
When did the 12AUW round motors come in? my friends Cooper S is June 1967.
johnl
Users browsing this forum: Bing [Bot] and 79 guests
