It is currently Wed Jul 30, 2025 1:06 am
 Post subject: cooper s
PostPosted: Mon Apr 11, 2016 7:28 pm
Hi i'm looking for a cooper s, i found this one on the net i'm not to sure if it a real cooper s. The numbers are Type YKG2S2 Car no:4637, Engine no:9F/SA/Y46206 but on the engine block its 9F/SA/Y43582 so i think its a replacement and the colour is 1/Burgundy red/toga white/3. Any help would be great thanks
 Post subject: Re: cooper s
PostPosted: Mon Apr 11, 2016 7:53 pm
That car has had its ID plate replaced and restamped. The ID plate is not a requirement for registration purposes but whenever this occurs you have to ask if the plate was restamped with the same details it was issued with from the factory or if the numbers have been changed to suit the owner. eg Engine number changes, Colour changes, or chassis number change.
I have not seen this car in person to confirm its an S but there are a lot of questions that need answering. There are also a lot of parts that missing or not for this model fitted to it.
Please have an expert look at this car before purchasing it.
PostPosted: Tue Apr 12, 2016 5:36 pm
Thanks for you help. From the bit of research i did i thought some of the things were odd.
PostPosted: Thu Apr 14, 2016 8:49 pm
Hi spotted a 1970 red Cooper s on carsales the plate has the number yg2s4 1685. It's not on the register does anyone know anything about this mini??
PostPosted: Thu Apr 14, 2016 8:51 pm
It looks like a good one from the photos.
PostPosted: Fri Sep 09, 2016 1:42 pm
Every other S has been sold lately anyone visit this one and can update on why this hasn't
1968 Morris Mini Cooper S
PostPosted: Fri Sep 09, 2016 2:09 pm
this one?
http://www.carsales.com.au/private/deta ... 387/?Cr=11
PostPosted: Fri Sep 09, 2016 2:15 pm
YKG2S2 4637 has been for sale for a while. http://www.carsales.com.au/dealer/detai ... -12614130/
A member on here called murray was asking about it back in January.
viewtopic.php?f=2&t=91695
Also mentioned here - viewtopic.php?f=2&t=92278
Here is a link to when it was for sale back in 2012. https://www.facebook.com/ShabbyShaun/po ... 5022584318
Then it was for sale on Car Sales for $30000 in January this year before the Healey shop listed it.
PostPosted: Fri Sep 09, 2016 4:57 pm
OK I knew there had to be a reason
PostPosted: Fri Sep 09, 2016 5:04 pm
It could be that it is made up of a mixture of Mk1 and Mk2 parts, there are some parts missing or incorrect parts fitted. And the ID plate looking a bit odd.
PostPosted: Sat Sep 10, 2016 2:58 am
A few things ain't right...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Sep 10, 2016 7:59 pm
Hmmm, I'd be erring on the side of caution :o
Good sleuth work GTO green.
66 MK 1 Cooper S
64 Grp N Cooper S
64 Grp N Cooper S (ex Bob Asher)
64 GRP N Cooper S (ex Fred Burley)
