https://ausmini.com/forums/
difference between upper control arms
https://ausmini.com/forums/viewtopic.php?f=2&t=93651
Author:  mooman10_0 [ Fri Sep 02, 2016 11:13 am ]
Post subject:  difference between upper control arms
Just wanting to know how to tell the difference between hydrolastic and rubber cone upper control arms?
Thanks,
Steve
Author:  drmini in aust [ Fri Sep 02, 2016 12:19 pm ]
Post subject:  Re: difference between upper control arms
try a 3/8 bolt through the horizontal hole. If it fits it is dry, if hole too small it is definitely hydro.
Author:  mooman10_0 [ Fri Sep 02, 2016 12:25 pm ]
Thanks for that :-)
Author:  miniron [ Fri Sep 02, 2016 3:54 pm ]
Another difference is the distance between the pivot shaft bore and the centre of the strut ball socket centre. The hydro arm distance is 1/8" longer than a dry arm.
IE: the dry strut is 1/8"closer to the pivot shaft.
If you use a hydro arm with dry suspension it makes the front suspension a little stiffer.
RonR
Edit: Changed shorter to longer and hydro to dry.
I realised my error when I woke at about 3am this morning.
I am claiming a senior moment/case of brain fade or any other excuse you are prepared to accept.
Author:  peterb [ Fri Sep 02, 2016 6:51 pm ]
Wouldn't it be softer with the higher leverage?
Author:  gtogreen1969 [ Fri Sep 02, 2016 7:06 pm ]
Thanks,
Steve
There is a bit of info here. http://www.minispares.com/article/MiniT ... suspension and http://www.mokeforum.com.au/index.php?topic=7678.0 ImageImage
Author:  mooman10_0 [ Sat Sep 03, 2016 7:12 am ]
awesome, they were definately hydro ones then :-)
Author:  TheMiniMan [ Sat Sep 03, 2016 9:53 am ]
miniron,,, the hydro knuckle hole is further away from the pivot pin
the dry knuckle hole is closer to the pivot pin
Author:  miniron [ Sat Sep 03, 2016 10:49 am ]
Miniman,
See my edit.
I am suitable chastened.
RonR
Author:  Gezo [ Sat Sep 03, 2016 11:22 am ]
Would a dry arm on hydro system make it softer or stiffer.
Author:  Phil 850 [ Sat Sep 03, 2016 11:26 am ]
Softer, as the wheel has a greater moment arm to work with to the displacer.
