White Roof... what shade? https://ausmini.com/forums/viewtopic.php?f=2&t=93643 |
Author: | Jenk [ Thu Sep 01, 2016 8:01 pm ] |
Post subject: | White Roof... what shade? |
Hi All, In relation to the White roof on a British Racing Green car... what is the actual shade of White? I've seen some Whites that look like creamy white and others that look White White, were both types factory?? cheers |
Author: | gtogreen1969 [ Thu Sep 01, 2016 8:12 pm ] |
Post subject: | Re: White Roof... what shade? |
Most two tone Mk1's painted in BRG had a Toga White roof. Then the whites went to Snow white and then Crystal white. The Crystal white is the cleanest and brightest then Snow then Toga. Have a look at the colour charts and it will show you the makeup of the colours. viewtopic.php?t=66469 |
Author: | Jenk [ Thu Sep 01, 2016 8:42 pm ] |
Thanks winabbey... Now to get my head around that ![]() ![]() |
Author: | Jenk [ Thu Sep 01, 2016 8:44 pm ] |
gtogreen1969 wrote: Most two tone Mk1's painted in BRG had a Toga White roof. Then the whites went to Snow white and then Crystal white. The Crystal white is the cleanest and brightest then Snow then Toga. Have a look at the colour charts and it will show you the makeup of the colours. viewtopic.php?t=66469 thanks gto |
Author: | gtogreen1969 [ Thu Sep 01, 2016 8:56 pm ] |
If you want something period correct then try and match up your cars date with a Green/White car on the registers. Otherwise just go for a white that you like to look at. Its funny how everyone that sees a dark green mini calls it BRG but looking at the MK1 S register the BRG cars only went for about 6 months. viewtopic.php?f=44&t=90843 |
Author: | Jenk [ Thu Sep 01, 2016 9:54 pm ] |
gtogreen1969 wrote: If you want something period correct then try and match up your cars date with a Green/White car on the registers. Otherwise just go for a white that you like to look at. Its funny how everyone that sees a dark green mini calls it BRG but looking at the MK1 S register the BRG cars only went for about 6 months. viewtopic.php?f=44&t=90843 Yes I want a period correct colour and a great help with the register I didn't think of that! thanks gto |
Author: | rodmac [ Thu Sep 01, 2016 10:05 pm ] |
I'm looking at exactly the same thing. Most 2-tone 66 - 67 British racing green or new British racing green cars would appear to have toga white on the roof. I had some mixed at my local paint shop and it looks grey. The mixer asked if it looked right? If you look at the colour charts they all look greyish and I checked with a friend who had some paint colour matched to the original paint on a car and it is almost a perfect match. What I'm trying to say is if you go toga white expect it to look quite a bit different (greyish) to what you expect but it does appear to be correct. Cheers Rod |
Author: | Jenk [ Fri Sep 02, 2016 7:17 am ] |
rodmac wrote: I'm looking at exactly the same thing. Most 2-tone 66 - 67 British racing green or new British racing green cars would appear to have toga white on the roof. I had some mixed at my local paint shop and it looks grey. The mixer asked if it looked right? If you look at the colour charts they all look greyish and I checked with a friend who had some paint colour matched to the original paint on a car and it is almost a perfect match. What I'm trying to say is if you go toga white expect it to look quite a bit different (greyish) to what you expect but it does appear to be correct. Cheers Rod Hi Rod, Thanks for that, were they able to mix it just by the paint name or do you have a code? if so would you mind passing it on? |
Author: | rodmac [ Fri Sep 02, 2016 7:32 am ] |
Gave them name and code The topic link gtogreen1969 gave above shows the code and approx colour but here they are. BMC/Leyland Colour: Toga white Code: 8452 Cheers Rod |
Author: | Jenk [ Fri Sep 02, 2016 5:04 pm ] |
rodmac wrote: Gave them name and code The topic link gtogreen1969 gave above shows the code and approx colour but here they are. BMC/Leyland Colour: Toga white Code: 8452 Cheers Rod Thanks Rod |
Author: | ianscampbell [ Sun Sep 04, 2016 12:14 pm ] |
Hi Jenk, My 1966 car is Toga White all over, a fairly greyish white. If you do decide on Toga White for the roof, I have the tinter settings as well as the codes for you. Ian. |
Author: | Jenk [ Thu Sep 08, 2016 8:47 pm ] |
ianscampbell wrote: Hi Jenk, My 1966 car is Toga White all over, a fairly greyish white. If you do decide on Toga White for the roof, I have the tinter settings as well as the codes for you. Ian. Hi Ian, sounds good appreciate that, any chance of a pic of your car? |
Author: | ianscampbell [ Sat Sep 10, 2016 12:42 pm ] |
Hi Jenk, Here's a pic of Dorris.. |
Author: | Jenk [ Mon Sep 12, 2016 6:15 pm ] |
ianscampbell wrote: Hi Jenk, Here's a pic of Dorris.. Hi Ian, Thanks for that can I have the codes etc please... by the way Doris is Gorgeous!! |
