It is currently Mon Jul 28, 2025 2:01 am
 Post subject: Cv shaft repair
PostPosted: Thu Sep 01, 2016 8:12 pm
So on my remote (?) gearbox/diff, the passenger cv shaft was pulled out where the small inner boot is. The outer cv joint came apart near the hub and the hub is separated from the shaft now. The spline is ok and i didnt lose any parts, is it just a matter of putting it all back together or do i need a new one?
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
 Post subject: Re: Cv shaft repair
PostPosted: Thu Sep 01, 2016 10:23 pm
I am having trouble understanding what you describe. Can you post any pics? Cheers
'68 Deluxe w/Metro engine
PostPosted: Thu Sep 01, 2016 11:52 pm
As long as the splines are undamaged the shaft can be reused.
How did it come apart? Failed rubber universal joint?
PostPosted: Fri Sep 02, 2016 6:47 am
Sounds like he has pot joints.
If shaft splines are undamaged, fit new wire 'circlips' on the ends and refit.
PostPosted: Fri Sep 02, 2016 7:04 am
Might have lost the circlip,,, or broke the axle at the outer CV joint
PostPosted: Fri Sep 02, 2016 7:41 am
Its hard to describe i gues. They just got yanked out when someone was helping. They came apart in 2 places, AFTER the rubber uni, there is the inner boot where it came off. The possible BROKEN part is just behind the hub where it was clunky. Ill get pics today.
PostPosted: Fri Sep 02, 2016 10:48 am
All sorted, the flange was sticky and pulled the joint out. Joint was fine and its all together again. Too wet to get under it today but =(
Users browsing this forum: Bing [Bot] and 74 guests
