It is currently Mon Jul 28, 2025 12:12 am
PostPosted: Sat Aug 27, 2016 10:01 pm
If I want to fit Hardy Spicer over rubber universal joints
do I need to change the output shaft covers to Hardie spicer?
anything else?
PostPosted: Sat Aug 27, 2016 10:09 pm
Remove
Install
PostPosted: Sat Aug 27, 2016 10:10 pm
Are you using the Hardy Spicer joints, flanges and drive yokes as used on the S and GT?
If so you need the S side covers, also S diff output shafts (with their collets and bolts).
If you are keeping the rubber uni's drive yokes and fitting QL5000 Hardy Spicer joints instead of rubber, then no.
PostPosted: Sat Aug 27, 2016 10:22 pm
timmy201 wrote:
Remove
Install
Nice reference photos. Thanks
PostPosted: Sat Aug 27, 2016 10:23 pm
I need the S diff output shafts with their collets and bolts
can you get them second hand or is it better new from a supplier?
PostPosted: Sat Aug 27, 2016 11:02 pm
These parts were also used in the MiniMatics. But their side covers don't fit manuals.
PostPosted: Sun Aug 28, 2016 6:32 am
gtogreen1969 wrote:
They are out of my build thread on here. Wasn't that a fun job!
PostPosted: Sun Aug 28, 2016 9:01 am
i hadn't realized the bolt/collet arrangement on the output shaft was so beefy. Is there room for a normal socket and is a replacement bolt available new/ uprated / etc? ( Great photo Tim).. I did quickly look at minispares site but couldn't find
PostPosted: Sun Aug 28, 2016 12:30 pm
where to buy second hand or new? S diff output shafts
PostPosted: Sun Aug 28, 2016 2:08 pm
ok , so complete with the output shaft... makes sense Thanks
PostPosted: Sun Aug 28, 2016 2:22 pm
Originals parts getting hard to come by.... (though I managed to get some NOS out of Chile a year or so ago !)
As an alternative can now buy Pot Joint Diff adapters for Hardy Spicer.... should leak less oil :lol: - but would need the Pot Joint diff parts (but should be easier to come by)
I got some via Harris Motorsport - but he's since retired ... the bling versions:
http://www.swiftune.com/Product/593/swiftune-hardy-spicer-output-flanges-for-atb-and-potjoint-diffs-pair.aspx
http://www.med-engineering.co.uk/products/transmission/drivetrain/med-hardy-spicer-adaptors
PostPosted: Sun Aug 28, 2016 2:52 pm
Try MKO. They have second-hand components and also conversion kits to pot joints.
http://minikingdomonline.com.au/product ... r-s-2hand/
http://minikingdomonline.com.au/product ... pot-joint/
PostPosted: Sun Aug 28, 2016 3:59 pm
Also need the collets and special washers bolts
can see the collets on the MKO site but not the special washers and bolts?
found the bolt but not the star washer? between the collets and oil seal.
PostPosted: Sun Aug 28, 2016 4:27 pm
i have the whole lot 2nd hand here in Bne if you`re keen
it`s an "engine-out" job, swap diff stuff over, shove engine back in
matt
0407135656
PostPosted: Mon Aug 29, 2016 8:31 am
I bought a couple of sets of the washers from the local fastener shop. Very cheap!
Edit: Some useful bits on eBay for you
http://www.ebay.com.au/itm/152220380438 ... EBIDX%3AIT
http://www.ebay.com.au/itm/191956034189 ... EBIDX%3AIT
