Rod-change box novice https://ausmini.com/forums/viewtopic.php?f=2&t=93595 |
Author: | justfanginaround [ Sun Aug 28, 2016 3:14 pm ] |
Post subject: | Re: Rod-change box novice |
from memory it's something like drop the diff cover and roll the diff centre out. rotate the gear selector untill the tang is clear of the the shift forks then the shift rod should be able to be removed from the rear of the box. might need some force but they do come out, I think the collar it slides in comes out with it, then its able to be knocked into 2nd and 4th to lock the mainshaft and as the good book says { Haynes manual } reassembly is the reversal of the removal procedure. ![]() |
Author: | TheMiniMan [ Sun Aug 28, 2016 4:37 pm ] |
the interspool lock can be rotated up & away from the 3x selector levers/fork with the diff out easy peasy rip the diff out, the selector rod can rotate, with the interspool lock, up & away from the 3x little forks remove the end cover (speedo drive housing) push the 1st/2nd slider ring into first gear,,, then knock the 3rd/4th slider ring into top gear remove pinion nut & pinion remove the double row bearing retainer slip-out the tab/plate that locates the leyshaft slip the leyshaft out roll the leygear up & out (after romoving the oil strainer pipe) then using the correct circlip pliers you can pop-out the circlip holding the first motion gear & bearing assy out punch out the 1st motion shaft/4th gear/bearing assy, (leaving it as a whole assy) then you can slip/lever/pry the whole mainshaft away from the main gearbox web, leaving you plenty of room to smack the double row bearing out so,,, push the double row bearing out fit new double row bearing , but don`t forget to swap over the cirlcip onto the new bearing ![]() & whack it all back together easy-peasy ![]() Matt |
Author: | Curly [ Sun Aug 28, 2016 5:18 pm ] |
Thanks Justfangingaround and Matt, the hardest bit will probably be letting the owner know he's up for $$$$. In a way I'm glad to have seen the problem before it caused a failure, but I could do without the extra work ![]() |
