It is currently Mon Jul 28, 2025 12:56 am
 Post subject: Bit of trivia..
PostPosted: Fri Sep 02, 2016 1:34 pm
Just found out my '67 Deluxe ignition key fits and starts my '62 Vespa! That is weird... :shock:
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
 Post subject: Re: Bit of trivia..
PostPosted: Fri Sep 02, 2016 2:31 pm
Lol my car keys for the Nissan open all but the boot of my mini. Apparently you can open one in fifty fords from XD to XF with your given key...not many cuts made at the factory...
Rob Forsyth
Miniot!!
PostPosted: Fri Sep 02, 2016 3:11 pm
I only found out when I parked the vespa and removed the keys, the Mini keys..... The 2 keys look the same and have the same cut. I'll have to try the Vespa key in the Mini when I get back to Oz..
67 Deluxe
Dry suspension
PostPosted: Fri Sep 02, 2016 6:30 pm
While I was an apprentice, in one of the classes the teacher showed the class that it was possible to open an LH Torana using a paddle pop stick & open & start an XD Falcon using the dipstick. Both of the cars were students cars so it wasn't like it was a pre-planned trick. Also between myself & quite a few of my mates who have had mid 90's Nissans (Pulsar, Skylines, S14's) it wasn't unusual that we could open & start each others cars.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Fri Sep 02, 2016 7:51 pm
Similarly the Toyota 70s and 80s cars - Corollas, Celicas all interchangeable amongst my family and mates
PostPosted: Fri Sep 02, 2016 8:00 pm
A few years ago I was at a well attended get together and I had a bet with a mate that my key would open his car.... I still have the VERY well worn key that probably came with my Mini 5 decades ago.
Not only did it open (and start) his car but worked the same on virtually every Mini we tried.... including one that the owner was very confident about as he'd just fitted new barrels to the doors and ignition...
Cheers, Ian
PostPosted: Fri Sep 02, 2016 9:01 pm
could open my old torana by looking too hard at the lock :|
mate had a commodore you could pop the doors on by punching the bonnet. funny as
PostPosted: Fri Sep 02, 2016 10:35 pm
i had an Nissan Urvan as did several of mates .we could unlock and or start most of each others .
someone i worked with had s Holden badged Nissan something i used to open it and leave notes on his seat.
65 panel van Sprog
73 panel van Iggy
PostPosted: Sat Sep 03, 2016 4:39 pm
my suzuki vitara key fits & works in my daihatsu handy van :-)
PostPosted: Sat Sep 03, 2016 6:07 pm
gawd Urvan......have you recovered yet? :lol:
PostPosted: Sat Sep 03, 2016 6:31 pm
KA/KB lasers all you needed was a very small screwdriver to use as a key.
1967 Morris Mini Deluxe 1310 with lots done, and almost ready to play.
http://www.affmotorsport.com
Previous;
1970 Mist Green Mini K
1967 Deluxe
1965 Deluxe
and a few for parts.
