https://ausmini.com/forums/
Leaking hydro pipe
https://ausmini.com/forums/viewtopic.php?f=2&t=93584
Author:  drmini in aust [ Sat Aug 27, 2016 4:31 pm ]
Post subject:  Leaking hydro pipe
My mate's Mini after Rylestone has a leaking hydro pipe with a pinhole, under the floor.
We could fix it with a short bit of copper pipe and 2x compression fittings, but the rest of the pipe is probably not much better.
Has anybody used Minispares nylon pipes over here? Car is a `71 Clubby.
http://minispares.com/product/Classic/S ... |Back%20to
Author:  Stibbsy [ Sat Aug 27, 2016 5:40 pm ]
Post subject:  Re: Leaking hydro pipe
When we repaired them in the dealership, we repaired by silver soldering. But the suspension was better drained, so you will require a hydro pump.
Author:  TK [ Sat Aug 27, 2016 5:56 pm ]
Kev, talk to Dave, sitnlo62. I remember he has the answer.
Author:  Convertible Mini [ Sat Aug 27, 2016 6:43 pm ]
I have successfully replaced a section with that Black Nylon pipe and compression fittings they use for truck Air brakes. It is even possible to replace the whole thing end to end without having to remove sub frames with that stuff.
Author:  drmini in aust [ Sat Aug 27, 2016 7:08 pm ]
Thanks Tony. I just remembered I have 10M of that 3/8" nylon under the house, and maybe the push connect fittings too. :)
[edit] It looks like the RH rear bag has sprung a leak. It's not the pipe. I have a bunch of s/h Deluxe ones, so it's pressure testing time tomorrow.
(Edit) A S/h bag was pressure tested for 3 days then fitted.
I also amused myself by re-hosing 2 other bags which had rotted hoses. :)
