It is currently Sun Jul 20, 2025 12:53 am
PostPosted: Sat Aug 27, 2016 8:08 am
I have a BMC Churchill hydro pump.
I need the instruction plate for the top, anyone know if I can still get one?
Vacuum pump seized, will have to try & work out the problem.
Thanks
Craig
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Sat Aug 27, 2016 11:16 am
Someone had the top plastic instruction plates remade. I'll see if I can find out who. Would you like one for your pump?
Edit: It was 850man on here.
In the meantime, these instruction sheets that came with each pump might help.
PostPosted: Sat Aug 27, 2016 11:20 am
Technical Bulletins to repair the pump are in this thread - viewtopic.php?f=2&t=84853
PostPosted: Sat Aug 27, 2016 11:22 am
Thanks for those!
PostPosted: Sat Aug 27, 2016 4:00 pm
More information including photos here - viewtopic.php?f=2&t=63794
PostPosted: Sat Aug 27, 2016 9:10 pm
Thanks for the info. Will try to print it.
Was mainly after the instruction plate attached to the top of the unit.
1927 Austin 7
