https://ausmini.com/forums/
Instruction plate for hydro pump
https://ausmini.com/forums/viewtopic.php?f=2&t=93573
Author:  cd [ Sat Aug 27, 2016 8:08 am ]
Post subject:  Instruction plate for hydro pump
I have a BMC Churchill hydro pump.
I need the instruction plate for the top, anyone know if I can still get one?
Vacuum pump seized, will have to try & work out the problem.
Thanks
Craig
Author:  winabbey [ Sat Aug 27, 2016 11:16 am ]
Post subject:  Re: Instruction plate for hydro pump
Someone had the top plastic instruction plates remade. I'll see if I can find out who. Would you like one for your pump?
Edit: It was 850man on here.
In the meantime, these instruction sheets that came with each pump might help.
Author:  winabbey [ Sat Aug 27, 2016 11:20 am ]
Technical Bulletins to repair the pump are in this thread - viewtopic.php?f=2&t=84853
Author:  DavidE [ Sat Aug 27, 2016 11:22 am ]
Thanks for those!
Author:  winabbey [ Sat Aug 27, 2016 4:00 pm ]
More information including photos here - viewtopic.php?f=2&t=63794
Author:  cd [ Sat Aug 27, 2016 9:10 pm ]
Thanks for the info. Will try to print it.
Was mainly after the instruction plate attached to the top of the unit.
