https://ausmini.com/forums/
water pump
https://ausmini.com/forums/viewtopic.php?f=2&t=93569
Author:  71morris [ Fri Aug 26, 2016 7:40 pm ]
Post subject:  water pump
water pump,
when fitted can you still shift the impellor by hand,
or can it only move by pulley and fan belt with fan fitted to harmonic balancer
Author:  gtogreen1969 [ Fri Aug 26, 2016 7:47 pm ]
Post subject:  Re: water pump
It should spin easily by hand without the pulley or fan.
Author:  71morris [ Fri Aug 26, 2016 7:57 pm ]
any causes for not spinning.
Author:  Harley [ Fri Aug 26, 2016 8:10 pm ]
Siezed bearing, engine sitting for long time and coolant has solidified and locked it up, or plastic fan has deformed and is rubbing on timing chain breather - I've seen all of those before.
Those would be more normal - not sure if say fitting a 1275 pump to an 850 would lock it though.
Whats yours doing? new or old and is it tight or locked completely?
Author:  oldblade [ Fri Aug 26, 2016 8:14 pm ]
when i fitted mine i was advised to check if it spun after install as you sometimes have to get a file out to enable it to spin freely
lucky for me mine just worked i have a 1275
Author:  71morris [ Fri Aug 26, 2016 8:20 pm ]
I can not spin it by hand, I just bought the engine from someone who said it has a brand new water pump installed.
There is coolant in it from previous owner, I have just fitted a heater blanking plate, can see coolant in it
no fan fitted, just the pulley, and it is not moving.
Author:  71morris [ Fri Aug 26, 2016 8:57 pm ]
can you store the engine without coolant to stop this happening again?
just ordered a new pump.
Author:  simon k [ Fri Aug 26, 2016 9:40 pm ]
this ^^
take the pump off, it'll start moving as loosen the bolts
Author:  TheMiniMan [ Sat Aug 27, 2016 3:27 pm ]
you probably have the large impellor type water pump fitted
often they need a couple of gaskets behind, or grind out the offending section of the water jacket/wall behind the pump where it clashes with the impellor
typical situation of someone "thinking" they`re fitting a better pump but not recognising the need to make sure the impellor clears the number one bore/wall/jacket
easy fix tho & better off with the large impellor pump anyways
Author:  71morris [ Sat Aug 27, 2016 4:46 pm ]
the bolts are to long through the pulley touching the pump even with the fan on
Author:  DavidE [ Sat Aug 27, 2016 5:16 pm ]
If the bolts are too long fit shorter ones!
Author:  simon k [ Sun Aug 28, 2016 5:50 pm ]
hacksaws work really well too...
Author:  Convertible Mini [ Mon Aug 29, 2016 9:39 pm ]
Should the fan have a spacer too explaining why the bolts are too long?
