It is currently Fri Jul 25, 2025 12:37 am
 Post subject: Dogbox group buy
PostPosted: Tue Jul 19, 2016 12:05 am
Hey guys.
I got some good pricing from MED for a group buy for dog gearkits.
http://www.med-engineering.co.uk/produc ... t-gear-kit
Pricing is as follows:
We can always work with you on the prices for the dog boxes. Please see below;
1 off price £1,300.00
3+ off price £1,200.00
5+ off price £1,075.00
There will be small freight and GST to add but will in the range of 180 quid cheaper than list price.
Total cost will be divided by parties so I am not looking to make anything out of it.
Call or txt me if you are interested. 0414 859 726
cheers Ben
The formula for the length of a piece of string is simple: Twice as long as from one end to the centre!
 Post subject: Re: Dogbox group buy
PostPosted: Tue Jul 19, 2016 6:23 pm
What sort of comparison to a std gear set ratios do these have?
Our dog engagement gear set has the following ratio’s
◾1st 2.239
◾2nd 1.568
◾3rd 1.244
◾4th 1.1
PostPosted: Tue Jul 19, 2016 6:37 pm
Same ratios as you posted
If you click on their link and on technical downloads tab it has more info
PostPosted: Tue Jul 19, 2016 7:29 pm
ken
for comparison
clubman gearset ratios
1st 2.583
2nd 1.711
3rd 1.250
4th 1.0
so higher first and second gear... good for holding onto second for longer but a bit more lazy off the lights
and also from minispares site
The stock helical "S" box has a first gear ratio of 3.2:1, second gear 1.916, third 1.357. The "S" 3 sync close ratio kit has a first gear of 2.573:1, second 1.722 and third 1.255; these numbers mean closer ratios to keep you in the torque range,,,,,,,
so these are very similar to 3 synchro
PostPosted: Wed Jul 20, 2016 6:13 pm
I could pull almost 60 mph in first gear if I revved it out with the sc/cr 3 synchro box in my S. Rarely needed to use the clutch to change gears, up or down, you just knew when the revs were right. And never missed the lack of synchro on first, just double de clutch and in it went on those rare occasions when needed.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Aug 25, 2016 7:32 pm
Hi Guys.
About to push the button on these to be sent so if there is anyone else would need to call me in very soon.
Cheers Ben 0414 859 726.
PostPosted: Thu Aug 25, 2016 10:04 pm
I've got a container coming out from the UK next month, might be able to help with shipping
Users browsing this forum: Bing [Bot] and 90 guests
