https://ausmini.com/forums/
I just broke my
https://ausmini.com/forums/viewtopic.php?f=2&t=93538
Author:  deluxe67 [ Tue Aug 23, 2016 9:43 am ]
Post subject:  I just broke my
drivers side 1/4 window latch. It snapped when I tried to close it fully :( . Assuming I can source another one, does anyone know what is involved in replacing it?
Thanks
Michael
Author:  miniron [ Tue Aug 23, 2016 9:48 am ]
Post subject:  Re: I just broke my
The catch is held to the window frame pivot stud/shaft by a metal pin which is pressed into the latch. You need to remove the pin to remove the catch from the window frame.
RonR
Author:  Stev0 [ Tue Aug 23, 2016 10:03 am ]
Where is it broken? I have seen NOS levers on eBay for about $160(!!). Yes, they have a pin pressed into the side which sits in a groove on the pivot. A real pain to remove. Other than already stated I don't believe you can buy the levers new.
Author:  TheMiniMan [ Tue Aug 23, 2016 12:18 pm ]
we have 2nd hand 1/4 window assys here (complete) but rubbers are not the best & would need replacing,
otherwise you could buy a 2nd hand one & fit it to your fram/glass assy
Matt
Author:  Aussie Brian [ Tue Aug 23, 2016 12:45 pm ]
A second pair of hands comes in handy when knocking out the pin. Take your time and you'll be fine. Can remember doing this task a long time ago when I replaced the 1/4 vent seal. I did it with the whole assembly off the door
Author:  deluxe67 [ Tue Aug 23, 2016 2:07 pm ]
Thanks guys. Just picked up the whole assembly 2nd hand, $25, good price I think. Now I have 2 choices, replace the rubber seal (very difficult) on that one and use it (a pain) or, remove the 2 pins and swap the handles over (potentially very difficult). Thinking I'll try and remove the pin on the broken one first and see how I go....
Author:  9YaTaH [ Tue Aug 23, 2016 2:56 pm ]
Michael
They can be a pain...but some pressure from outside near the latch (to compress the rubber) helps them last...not whilst mobile necessarily :D
