It is currently Mon Jul 28, 2025 1:30 am
PostPosted: Thu Aug 18, 2016 1:25 pm
If memory serves is it charge light under the temp, oil pressure under the fuel, and hand brake warning light on the speedo side?
Either way after quite sometime getting the whole thing rewired then getting it home and back together the only warning light that works is the high beam! Oil pressure I think is because a gauge is fitted (before I bought it) although light worked prior, the others who knows AND the fuel gauge doesn't want to work (yes has fuel). Can't win :roll:
PostPosted: Thu Aug 18, 2016 1:54 pm
This the Jan 1977 version of the driver's handbook. I think there were various minor changes during the period of production.
PostPosted: Thu Aug 18, 2016 2:02 pm
Hi Turbo
There is a brand new old stock 2 pod for sale on eBay at the mo. It is complete with all the bits and pieces.
https://www.ebay.com.au/itm/162165747749
Eiles
PostPosted: Thu Aug 18, 2016 5:08 pm
one is 'alt' the other light is 'oil'
edit; the only handbrake light on a Clubby was put on the top dash pad (later minis)
PostPosted: Fri Aug 19, 2016 7:48 am
Cheers guys, make a bit more sense
PostPosted: Fri Aug 19, 2016 8:54 am
Maybe you need a new printed circuit.
"Let us remove your "SHORTS"
