https://ausmini.com/forums/
Hs2 throttle return
https://ausmini.com/forums/viewtopic.php?f=2&t=93473
Author:  Thorlek [ Wed Aug 17, 2016 1:01 pm ]
Post subject:  Hs2 throttle return
Hi all,
My mate is retoring a 62 850.
He isn't sure how the throttle return spring works on it.
On my hs4 there is a bracket between the carb and the manifold that the spring connects to.
Are hs2's the same? Or do the return springs connect somewhere else?
Author:  timmy201 [ Wed Aug 17, 2016 2:08 pm ]
Post subject:  Re: Hs2 throttle return
From memory, mine had a little bracket on the exhaust clamp?
Part #30 i the diagram - 12A5
http://www.minispares.com/catalogues/cl ... spx?1~6~58
Author:  DavidE [ Wed Aug 17, 2016 2:09 pm ]
Correct.
Author:  timmy201 [ Wed Aug 17, 2016 2:22 pm ]
It's just a bent piece with a hole in each end. There is a diagram here
http://mk1-forum.net/viewtopic.php?f=8& ... hilit=12a5
